Timestamped Map
IMD Listuser
imd_listuser at COMCAST.NET
Mon Oct 25 15:01:25 EDT 2004
Hi Brent
Thanks for the reply.
I understand what you are saying about having to pass in the
map_timestamp_feature_text in the url.
Id like to avoid that and have the server set the time on the image. Is
there anything that I can use to allow me to do so? Seems like there
ought to be....
Cheers
Charlie
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Brent Fraser
Sent: Monday, October 25, 2004 12:31
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Timestamped Map
Charlie,
While the [imagedate] "variable" looks like MapServer CGI variable,
it's not. It's just something I invented (well, borrowed) for a
particular implementation. The Mapserver CGI variable you will be using
for the map file snippet below is map_TimeStamp_feature_text. You set
it in the URL the client passes to the server. It won't work to set
[imagedate] in the URL as Mapserver has no clue about that variable, and
has no way to set text in the mapfile. It DOES have a way to substitute
the entire contents of a map file object using the map_ syntax. See the
bottom of http://mapserver.gis.umn.edu/doc42/cgi-reference.html
("Changing map file
parameters...")
What does your URL look like?
Brent
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, October 25, 2004 9:44 AM
Hi
Unfortunately when I try to duplicate your code, the only thing that
appears on the map is "Terra MODIS [imagedate] [imagetime] UT". Even if
I substitute a known cgi variable like [mapext], it does not get
evaluated prior to being drawn on the map.
Hmmm. Any Ideas
Charlie
Sent: Monday, October 25, 2004 10:46
Charlie,
I'm not sure if this is the best way but we did something similar a
couple of years ago using the following layer definition:
LAYER
NAME "TimeStamp"
TYPE ANNOTATION
STATUS DEFAULT
TRANSFORM FALSE
FEATURE
POINTS 20 20 END # Text in Upper-left
TEXT "Terra MODIS [imagedate] [imagetime] UT"
END
CLASS
LABEL
COLOR 255 255 255
OUTLINECOLOR 0 0 0
TYPE TRUETYPE
FONT comic
SIZE 16
POSITION AUTO
FORCE TRUE
OFFSET 10 10
PARTIALS FALSE
WRAP ","
END # Label
END # CLASS
END
In our case we pre-processed the map file to substitute the "[imagedate]
[imagetime]" with the date the data was aquired (not the date the map
graphic was generated) by using some purpose-built software on the
server.
I think you would be able to use a CGI variable to change the text, but
I haven't tried it. I think the CGI syntax would be something like:
...&map_TimeStamp_feature_text=Terra+Modis+20041025&...
and you'll likely need URL encoding for characters other than
alphanumerics.
Brent Fraser
GeoAnalytic Inc.
Sent: Monday, October 25, 2004 7:38 AM
Subject: [UMN_MAPSERVER-USERS] Timestamped Map
Greetings,
Id like to place a timestamp on each map that is created.
What is the bext way to do this? Im using mapserver cgi version 4.2 and
Id prefer to not change this configuration. If possible Id like to do so
using the map file or dhtml.
TIA
Charlie
