Timestamped Map
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Oct 25 15:18:40 EDT 2004
Charlie,
Well, one thing the comes to mind is to write a bug on this so
[current_data], [current_time] are variables in the mapfile that are set
appropriately by mapserver in a future rev.
To your immediate problem, you could write a simple shell script wrapper
that your url hits and have it append the map_timestamp_feature_text in
the url along with the current data/time as text, then have it exec
mapserver. This would allow you to do it transparently on the server
using the existing mechanisms.
-Steve W.
IMD Listuser wrote:
> Hi Brent
> Thanks for the reply.
> I understand what you are saying about having to pass in the
> map_timestamp_feature_text in the url.
> Id like to avoid that and have the server set the time on the image. Is
> there anything that I can use to allow me to do so? Seems like there
> ought to be....
> Cheers
> Charlie
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Brent Fraser
> Sent: Monday, October 25, 2004 12:31
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Timestamped Map
> Charlie,
> While the [imagedate] "variable" looks like MapServer CGI variable,
> it's not. It's just something I invented (well, borrowed) for a
> particular implementation. The Mapserver CGI variable you will be using
> for the map file snippet below is map_TimeStamp_feature_text. You set
> it in the URL the client passes to the server. It won't work to set
> [imagedate] in the URL as Mapserver has no clue about that variable, and
> has no way to set text in the mapfile. It DOES have a way to substitute
> the entire contents of a map file object using the map_ syntax. See the
> bottom of http://mapserver.gis.umn.edu/doc42/cgi-reference.html
> ("Changing map file
> parameters...")
> What does your URL look like?
> Brent
> ----- Original Message -----
> From: "IMD Listuser" <imd_listuser at COMCAST.NET>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Monday, October 25, 2004 9:44 AM
> Hi
> Unfortunately when I try to duplicate your code, the only thing that
> appears on the map is "Terra MODIS [imagedate] [imagetime] UT". Even if
> I substitute a known cgi variable like [mapext], it does not get
> evaluated prior to being drawn on the map.
> Hmmm. Any Ideas
> Charlie
> Sent: Monday, October 25, 2004 10:46
> Charlie,
> I'm not sure if this is the best way but we did something similar a
> couple of years ago using the following layer definition:
> LAYER
> NAME "TimeStamp"
> TYPE ANNOTATION
> STATUS DEFAULT
> TRANSFORM FALSE
> FEATURE
> POINTS 20 20 END # Text in Upper-left
> TEXT "Terra MODIS [imagedate] [imagetime] UT"
> END
> CLASS
> LABEL
> COLOR 255 255 255
> OUTLINECOLOR 0 0 0
> TYPE TRUETYPE
> FONT comic
> SIZE 16
> POSITION AUTO
> FORCE TRUE
> OFFSET 10 10
> PARTIALS FALSE
> WRAP ","
> END # Label
> END # CLASS
> END
> In our case we pre-processed the map file to substitute the "[imagedate]
> [imagetime]" with the date the data was aquired (not the date the map
> graphic was generated) by using some purpose-built software on the
> server.
> I think you would be able to use a CGI variable to change the text, but
> I haven't tried it. I think the CGI syntax would be something like:
> ...&map_TimeStamp_feature_text=Terra+Modis+20041025&...
> and you'll likely need URL encoding for characters other than
> alphanumerics.
> Brent Fraser
> GeoAnalytic Inc.
> Sent: Monday, October 25, 2004 7:38 AM
> Subject: [UMN_MAPSERVER-USERS] Timestamped Map
> Greetings,
> Id like to place a timestamp on each map that is created.
> What is the bext way to do this? Im using mapserver cgi version 4.2 and
> Id prefer to not change this configuration. If possible Id like to do so
> using the map file or dhtml.
> TIA
> Charlie
