Help: Setting Virtual Spatial data
Janeks Kamerovskis
janeks.kamerovskis at SILVA.LV
Tue Oct 26 03:11:47 EDT 2004
Hi, All!
I tried to set up Virtual spatial data layer using ODBC:
I made virtual data file: virt.ovf
And tested it with ogrinfo.exe:
That says:
INFO: Open of `e:\MapServer\MapDefs\virt.ovf'
using driver `VRT' successful.
I put virtual layer in map file.
But server responds:
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'mylayer'. in E:\webFolders\ipasumi\test2.php on line 57
Warning: [MapServer Error]: msOGRFileOpen(): Open failed for OGR connection
`E:\MapServer\mapDefs\virt.ovf'. File not found or unsupported format. in
What could be wrong?
virt.ovf
<OGRVRTDataSource>
<OGRVRTLayer name="mylayer">
<SrcDataSource>ODBC:MyTest,kraut1/SrcDataSource>
<SrcLayer>kraut1</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="x" y="y"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Layer in map file:
LAYER
NAME "mylayer"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "E:\MapServer\mapDefs\virt.ovf" # the name and path to
the virtual.ovf file, relative to shapepath may work?
DATA "kraut1" # the name of the OGRVrtLayer
STATUS ON
# LABELITEM kraut1 #may need to use table.name or just name depending
on your OVF file.
# PROJECTION
# "init=epsg:4326"
# END
CLASS
SYMBOL 1
SIZE 6
COLOR 255 0 0
LABEL
SIZE MEDIUM
TYPE BITMAP
COLOR 0 0 0
END
END
END
brgds
Janeks Kamerovskis
