Can't figure ItemQuery Out
Leo Dolan
leo at ENNEAD.COM
Wed Oct 27 01:43:44 EDT 2004
Ryan,
Thanks, I think I finally cracked it. It was actually a problem with the
extent. I had thought that the "shapes" clause would search all shapes, but
this didn't seem to be the case. I had also tried the extent of the map
earlier in the "mapext" field, but got the order wrong (since I used the
same order from the map file, and not minx, miny, maxx, maxy). Once I fixed
the extent, and then with the regular expressions you suggested below, all
is working perfectly now.
Thanks again for the suggestion!
-Leo
----- Original Message -----
To: "Leo Dolan" <leo at ENNEAD.COM>; <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, October 26, 2004 5:21 PM
Subject: RE: [UMN_MAPSERVER-USERS] Can't figure ItemQuery Out
> Leo,
> On a lark, try it as a regular expression:
> ('[A1RENUM]' =~ /^33768-000-000$/)
> Adam
> -----Original Message-----
> From: Leo Dolan [mailto:leo at ENNEAD.COM]
> Sent: Tuesday, October 26, 2004 12:50 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Can't figure ItemQuery Out
> I've been working on this all day and can't seem to figure it out.
> I'm on Mapserver v 4.2 on Windows. Here is the Mapfile:
> MAP
> NAME "CRA 2000"
> STATUS ON
> SIZE 600 420
> IMAGECOLOR 230 230 230
> IMAGETYPE PNG24
> EXTENT 1518976.125000 454307.531250 1565951.625000 426016.062500
> SHAPEPATH "shapefiles/parcels2000"
> WEB
> TEMPLATE "printable.html"
> IMAGEPATH "tmp/" # full path to image tmp dir, so cgi can find it
> IMAGEURL "tmp/" # url location of image tmp dir, so web browser can
find
> it
> END # Web Interface Options
> QUERYMAP
> STATUS ON
> STYLE SELECTED
> COLOR 255 255 0
> END
> # Start of layer definitions
> LAYER # start of the "main" layer object
> NAME "2000_Bay_County"
> DATA parcels2000
> STATUS ON
> TYPE POLYGON
> TEMPLATE "parcels2000_query.html"
> HEADER "parcels2000_header.html"
> FOOTER "parcels2000_footer.html"
> CLASS
> NAME "Bay County 2000 Parcels"
> OUTLINECOLOR 0 204 0
> END
> END # end of layer object
> END # Map File
> And here is the form that submits a test query:
> <form name="test" action="mapserv.exe" method="get" target="info">
> <input type="hidden" name="mapext" value="shapes">
> <input type="hidden" name="map" value="cra2000.map">
> <input type="hidden" name="mode" value="itemquery">
> <input type="hidden" name="qlayer" value="2000_Bay_County">
> <input type="hidden" name="qitem" value="A1RENUM">
> <input type="hidden" name="qstring" value="33768-000-000">
> <input type="submit" value="Get Parcel Query">
> </form>
> Anytime I submit this, however, I get the following message:
> msQueryByAttributes(): Search returned no results. No matching record(s)
> found.
> I've tried multiple variations, such as type in the parameters into the
URL,
> eliminating the qitem value and passing qstring as
> ('[A1RENUM]'='33768-000-000'), etc. I know that there is a value in the
> parameters table for '33768-000-000', and I've tried other values for it,
> and other fields to try and query against with no succes. If somebody
> knows what I'm doing wrong, I would appreciate being pointed in the right
> direction. Thanks in advance!
> Sincerely,
> Leo T. Dolan
