[UMN_MAPSERVER-USERS] query on oraclespatial using OGR/OCI
Fortin,Nicolas [SteFoy]
nicolas.fortin at EC.GC.CA
Wed Oct 27 10:44:12 EDT 2004
Hi Fernando,
I'm glad to hear it!
I hope someone will compile the 4.4.0 version with this new oracle support ... for windows.
If someone compile it as said above, I'd be glad to know about it.
Good works!!
Nicolas
PS: Thanks to Jane Gehan and Kari A. Geurts who helped me solve my posting problem.
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU <mailto:MAPSERVER-USERS at LISTS.UMN.EDU> ] De la part de FERNANDO SIMON Envoyé : Friday, October 22, 2004 2:57 PM À : MAPSERVER-USERS at LISTS.UMN.EDU Objet : Re: [UMN_MAPSERVER-USERS] query on oraclespatial using OGR/OCI
Hi Javier,
Yes, "the querys" are working correctly now, I tested the query functions with cgi mode an mapscript functions and both kinds work correctly.
The query support is finished, now I'm working with others supports for the oraclespatial. So I believe that the querry support will be include in the next version of mapserver.
Thank's for the help.
Fernando Simon - simon at inf.univali.br
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada http://g10.cttmar.univali.br <http://g10.cttmar.univali.br/>
Quoting Javier Castillejo Montes <jcastil1 at TRAGSA.ES>:
> Hi Fernando,
> I understand that you did some work on the mapserver files and now,
> your queries are working?
> As Pierre knows I'm using mapserver with oracle spatial and my next
> step is "The Queries".... If you need any help do not hesitate to told
> me. I'm starting with "The Queries" work, but I will try to help.
> I think that I'm going to use php to generate the queries. It isn't
> the best way, but, for now, Is the only way I know.
> THanks
> -----Mensaje original-----
> De: Fernando S. [mailto:simon at INF.UNIVALI.BR <mailto:simon at INF.UNIVALI.BR> ]
> Enviado el: jueves, 21 de octubre de 2004 18:31
> Para: MAPSERVER-USERS at LISTS.UMN.EDU
> Asunto: Re: [UMN_MAPSERVER-USERS] query on oraclespatial using OGR/OCI
> Hi Pierre,
> The query functions can be possible in the next version of the
> Oracle Spatial support. I implemented these functions here in my
> computer and I believe that this functions will be include in the next
> version of native support.
> I don't know how the OGR implement the query function but this
> problem appear when you use functions that use the primary filter like
> SDO_FILTER.
> Here the problem disappear when I recreate the indexes without
> SDO_LEVEL. Another point is the tolerance, you can try set a small
> value for Tolerance like 0.00001.
> bluecarto at free.fr wrote:
> >First question : how can you query oracle layers if you don't use OGR
> >? I
> mean
> >the function are not implemented for oraclespatial connectiontype.
> >I had already try you suggestion (ommitting the SDO_LEVEL parameter).
> >That
> could
> >be a good idea, but, sadly, it doesn't give any better result.
> >I'm using Oracle 10g on Debian or Oracle 9.2 on RedHat.
> >In my sample the result given seem to be the first record in the
> >table.
> >Regards
> >Pierre
> >Selon FERNANDO SIMON <simon at inf.univali.br>:
> >>Hi Pierre,
> >> I don't use OGR but your problem can be with the spatial index.
> >>I saw this problem with the 10G version.
> >> In the 10G version the Oracle don't recommend use SDO_LEVEL when you
> >>create
> >>the spatial index. In my tests problems appears when I set the SDO_LEVEL,
> the
> >>result doesn't correspond whant I expected.
> >> I don't know if the problem occur with others Oracle Spatial
> versions.
> >>But
> >>you can try with or without SDO_LEVEL.
> >>Quoting Pierre GIRAUD <bluecarto at FREE.FR>:
> >>> I'm still having difficulties to use mapserver queries on a oracle
> layer.
> >>> Before I report a bug, I would like someone to test the following
> >>>SQL statement and mapfile, and agree that something is going wrong,
> >>>or tell me I am missing
> >>>something obvious.
> >>> Thx
> >>> Pierre GIRAUD
> >>> camptocamp.com
> >>>---------SQL statement--------------
> >>>DROP table mytable;
> >>>CREATE TABLE MYTABLE (
> >>> GID VARCHAR(20),
> >>> geometry MDSYS.SDO_GEOMETRY);
> >>>insert into MYTABLE (GID,GEOMETRY) values (
> >>> '1',
> >>> mdsys.sdo_geometry(
> >>> '2003',
> >>> null,
> >>> null,
> >>> mdsys.sdo_elem_info_array(1,1003,1),
> >>> mdsys.sdo_ordinate_array(1,1, 1,4, 4,4, 4,1, 1,1))
> >>> '2',
> >>> mdsys.sdo_geometry(
> >>> '2003',
> >>> null,
> >>> null,
> >>> mdsys.sdo_ordinate_array(6,1, 6,4, 9,4, 9,1, 6,1))
> >>> '3',
> >>> mdsys.sdo_geometry(
> >>> '2003',
> >>> null,
> >>> null,
> >>> mdsys.sdo_ordinate_array(1,6, 1,9, 9,9, 9,6, 1,6))
> >>>delete from user_sdo_geom_metadata where table_name like 'MYTABLE';
> >>>insert into user_sdo_geom_metadata
> >>>(table_name,column_name,diminfo,srid)
> >>>values ('MYTABLE','GEOMETRY',
> >>>mdsys.SDO_DIM_ARRAY(mdsys.SDO_DIM_ELEMENT('X', 0, 10, 0.1),
> >>>mdsys.SDO_DIM_ELEMENT('Y', 0, 10, 0.1)),
> >>>NULL);
> >>>drop index q_mytable;
> >>>create index Q_MYTABLE on MYTABLE(GEOMETRY) indextype is
> >>>MDSYS.spatial_index parameters ('SDO_LEVEL=6');
> >>>---------mapfile---------------
> >>>NAME DEMO
> >>>STATUS ON
> >>>SIZE 500 300
> >>>EXTENT 0 0 10 10
> >>>IMAGECOLOR 255 255 255
> >>>WEB
> >>> IMAGEPATH "/var/www/images/"
> >>> IMAGEURL "images/"
> >>>END
> >>>LAYER
> >>> NAME squares
> >>> TYPE POLYGON
> >>> STATUS ON
> >>># CONNECTIONTYPE oraclespatial
> >>># CONNECTION "scott/tiger at orcl"
> >>> CONNECTION "OCI:scott/tiger at orcl"
> >>> CONNECTIONTYPE OGR
> >>># DATA "select * from mytable"
> >>> DATA "mytable"
> >>> TEMPLATE "ttt"
> >>> CLASS
> >>> SIZE 10
> >>> COLOR 255 255 255
> >>> OUTLINECOLOR 200 200 200
> >>> END
> >>>END
> >>>END
> >>>Selon bluecarto at free.fr:
> >>>> Hello,
> >>>>Following the good advices of Frank Warmerdam, I improve in using
> oracle
> >>>>spatial
> >>>>data with spatial indexes. For now, I know that I should not use
> >>>>sql statements in the mapfile but queries directly to the table :
> >>>> DATA "my_table"
> >>>>instead of
> >>>> DATA "select * from my_table"
> >>>>Both return the same images. Shapes are well drawn, and labeling
> >>>>is
> >>>correct.
> >>>>But the first (more performant) statement doesn't give good
> >>>>results to
> a
> >>>>query.
> >>>>The data returned doesn't correspond to what is expected. And no
> >>>>shape
> is
> >>>>highlighted.
> >>>>Do someone using Oracle have same problems ?
> >>>>Pierre GIRAUD
> >>>>camptocamp.com
> >>Este e-mail foi enviado pelo webmail do curso de
> >> Ciência da Computação - UNIVALI
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041027/3c81935d/attachment.html
