getLegendGraphic - GD Library Error
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Wed Oct 27 17:38:45 EDT 2004
Astrid Emde wrote:
> Hello,
> wenn I send my getLegendGraphic-Request I get the following error:
> msDrawLegend(): GD library error. Unable to initialize image.
> msImageCreateGD(): Image handling error. Cannot create GD image of size
> 60 x 0.
> Does anyone know, what can be wrong? How can I solve the problem?
Is this using the 4.4.0-beta1? If not then the first thing to do would
be to try 4.4.0-beta1.
I tried hacking together a quick mapfile using your layer and legend
definitions to reproduce this with your URL but I don't get this error.
I do get a legend with one item on it. I'll attach my test mapfile, you
may want to try it at your end.
If you still get this error with the latest version then perhaps you
could file a bug with a small testcase to reproduce and one of us can
have a look (your testcase should include mapfile, symbolset and
fontset, but data shouldn't be needed).
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
MAP
EXTENT 1 1 10 10
SIZE 300 300
# http://sb1/cgi-bin/mapserv_43?map=/tmp/testlegend.map&request=getLegendGraphic&VERSION=1.1.1&LAYER=poi&FORMAT=text/html
# Start of legend
LEGEND
STATUS ON
KEYSIZE 40 20
KEYSPACING 10 10
IMAGECOLOR 128 128 128
#OUTLINECOLOR 0 0 0
LABEL
COLOR 120 120 120
# TYPE TRUETYPE
# FONT "arial"
# SIZE 12
TYPE BITMAP
SIZE MEDIUM
END # END LABEL
END #LEGEND
LAYER
NAME 'poi'
STATUS ON
CONNECTIONTYPE postgis
CONNECTION 'user=pgsql dbname=test host=localhost'
DATA "the_geom from poi"
TYPE POINT
PROJECTION
'init=epsg:31494'
END
METADATA
'WMS_SRS' 'epsg:31494'
'WMS_TITLE' 'test'
'WMS_FEATURE_INFO_MIME_TYPE' 'text/html'
END
CLASSITEM "symbol"
CLASS
NAME "Geldautomat"
EXPRESSION /./
MINSCALE 0
MAXSCALE 1000
STYLE
# SYMBOL "geldautomat_50"
SYMBOL 0
SIZE 10
END
END
END #LAYER
END #MAP
