Mapscript - problem with binary grid (ADF)
Marcin Zajączkowski
mszpak at WP.PL
Fri Oct 29 13:47:03 EDT 2004
can anyone please help me, i encountered two problems using mapscript
and am unable to figure out the source of the problems.
I have stopped using mapserver executable /cgi-bin/mapserv and started
using mapscript.
1) When using /cgi-bin/mapserv i am able to view grid maps saved in .adf
format, when i started using mapscript they are not drawn.
2) When i try executing a query using mapscript everytime i get no
results (no objects found). When executing the same query on both
/cgi-bin/mapserv and mapscript, /cgi-bin/mapserv find the proper results
and mapscript gets no results.
In both describled cases i use the same maps.
Below are the script used for generating proper images and
/cgi-bin/mapserv and mapscript compile options (in both cases i
downloaded them from the web not compiled them myself)
vars.php
<?php
$VARS["map"] = $_GET[map];
if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
@dl("php3_mapscript.dll");
else
dl("php_mapscript.so");
// Odczyt mapy
if( ! $g_Map )
$g_Map = ms_newMapObj( $VARS["map"] );
$g_Map->web->set("log", "c:/temp/log.log");
$g_Map->set("debug", 1);
viewMap.php
<?php
include('vars.php');
function MS_NINT($x){ return (($x) >= 0.0 ? ((int) (($x)+.5)) : ((int)
(($x)-.5))); }
function MS_CELLSIZE($min,$max,$d){ return (($max - $min)/$d); }
function MS_MAP2IMAGE_X($x,$minx,$cx){ return (MS_NINT(($x - $minx)/$cx));
function MS_MAP2IMAGE_Y($y,$maxy,$cy){ return (MS_NINT(($maxy - $y)/$cy));
function MS_IMAGE2MAP_X($x,$minx,$cx){ return ($minx + $cx*$x); }
function MS_IMAGE2MAP_Y($y,$maxy,$cy){ return ($maxy - $cy*$y); }
if( $_GET[layers] )
$g_ShowLayer = explode(' ', $_GET[layers]);
if( is_array($g_ShowLayer) )
reset($g_ShowLayer);
while ( list($index, $layerName) = each($g_ShowLayer) )
$layer = $g_Map->getLayerByName($layerName);
if ( $layer ) // jeśli była taka wartswa
ustawiamy jej widocznosc podczas rysowania
if( $layer->set( "status", MS_ON ) == -1 )
die( "set('status', MS_ON): $layerName" );
else
die( "$layerName: Layer Not Found" );
if($_GET[mapext])
$mapext = explode(" ", $_GET[mapext]);
$g_Map->extent->setextent($mapext[0], $mapext[1], $mapext[2],
$mapext[3]);
switch( $_GET[mode] )
// MAP
case "map":
$img = $g_Map->draw();
$url = $img->saveWebImage(MS_PNG, 0, 0, 0);
break;
// REFERENCE
case "reference":
$img = $g_Map->drawReferenceMap();
break;
// SCALEBAR
case "scalebar":
switch($_GET[map_scalebar_units])
case "kilometers":
$g_Map->scalebar->set("units", MS_KILOMETERS);
break;
case "miles":
$g_Map->scalebar->set("units", MS_MILES);
break;
default:
$g_Map->scalebar->set("units", MS_METERS);
break;
$img = $g_Map->drawScaleBar();
break;
case "query":
case "nquery":
$imgext = explode(" ", $_GET[imgext]); // [minx,
miny, maxx, maxy]
$imgxy = explode(" ", $_GET[imgxy]); // [clickx,
clicky]
$imgsize = explode(" ", $_GET[imgsize]); //
[imgwidth, imgheight]
$imgbox = explode(" ", $_GET[imgbox]); //[minx,
miny, maxx, maxy]
$g_Map->setextent($imgext[0],$imgext[1], $imgext[2],
$imgext[3]);
$cellX = MS_CELLSIZE( $imgext[0], $imgext[2], $imgsize[0]
$cellY = MS_CELLSIZE( $imgext[1], $imgext[3], $imgsize[1]
$mapX = MS_IMAGE2MAP_X( $imgxy[0], $imgext[0], $cellX);
$mapY = MS_IMAGE2MAP_Y( $imgxy[1], $imgext[3], $cellY);
$rect = ms_newRectObj();
$rect->setextent($imgext[0],$imgext[1], $imgext[2],
$imgext[3]);
$mapPoint = ms_newPointObj();
$mapPoint->setXY( $imgxy[0], $imgxy[0], 0 );
// $g_Map->zoomrectange( $rect,
$imgsize[0], $imgsize[1], $g_Map->extent);
echo "<pre>$imgxy[0], $imgxy[1] (Image coordinates)\n".
"$mapX $mapY (Map coordinates)\n";
print_r($_GET);
//print_r($g_Map);
@$result = $g_Map->queryByPoint($mapPoint, MS_SINGLE,
300);
echo "\nresult: $result \n";
if( $result == MS_SUCCESS )
echo "MS_SUCCESS";
for( $i = 0; $i < $g_Map->numlayers; $i++ )
$layer = $g_Map->getLayer($i);
if( $layer->status == MS_ON )
@$result = $layer->queryByPoint($mapPoint,
MS_SINGLE, 3);
echo "result: $result,
".$layer->getNumResults()."\n";
break;
default:
$url = "graphics/transparent_pixel.gif";
break;
if(isset($img))
$img->free();
if($g_Map->web->error)
echo $g_Map->web->error;
header("Location: $url");
/cgi-bin/mapserv -v
MapServer version 4.2-beta3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
phpinfo();
PHP MapScript Version ($Revision: 1.194.2.3 $ $Date: 2004/05/13 21:37:44
