Help with my instalation of MapServer-4.2.5
Romolo Manfredini
romoloman at HOTMAIL.COM
Fri Oct 29 18:16:17 EDT 2004
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Saturday, October 30, 2004 12:06 AM
Subject: Re: [UMN_MAPSERVER-USERS] Help with my instalation of
MapServer-4.2.5
> Cartman wrote:
> > Hi, I am instaling MapServer on Linux Red Hat 9.0 and
> > I have some problems.
> > This is my script for instalation.
> > ./configure
> > --with-freetype=/usr/local/include/freetype
> > --with-zlib=/usr/include --with-png=/usr/lib
> > --with-xpm=/usr/lib/gimp/1.2/plug-ins/
> > --enable-force-freetype1 --with-wmclient
> > --with-org=/usr/local/bin
> > --with-tiff=/usr/local/include
> > --with-ming=/usr/include
> > --with-curl-config=/usr/local/bin
> > --with-httpd=/usr/sbin/httpd
> > --with-php=/usr/local/include/php/main
> > --with-libiconv=/usr/local/lib
> > And then, when I run make, the follow error is showed.
> > ./libmap.a(mapswf.o)(.text+0x488e): In function
> > `msFreeImageSWF':
> > : referencia a `destroySWFMovie' sin definir
> > ./libmap.a(mapswf.o)(.text+0x4a01): In function
> > `msDrawVectorLayerAsRasterSWF':
> > : referencia a `SWFMovie_add' sin definir
> > ./libmap.a(mapswf.o)(.text+0x1478): In function
> > `AddMouseActions':
> > : referencia a `SWFButton_addAction' sin definir
> > collect2: ld devolvió el estado de salida 1
> > make: *** [shp2img] Error 1
> > What`s happen?
You need libming 0.2a not the latest version 0.3, otherway mapserver doesn't
compile.
Best regards,
Romolo Manfredini
