Mapserver CGI or C API question
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Fri Oct 29 18:01:13 EDT 2004
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of ANDY CANFIELD
> Sent: Friday, 29 October, 2004 17:51
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Mapserver CGI or C API question
> Tom,
> I already have XML parsing built into the app for some other
> stuff it does so that sounds like a good solution to me. Can
> I run that against a regular mapfile with regular layers or
> do I need to set up wms layers? Thanks, Andy
OGC:WMS serves images and simple point based queries. For enhanced
queries, you need to setup your mapfile for OGC:WFS. Check out the
OGC:WFS howto for this
(http://mapserver.gis.umn.edu/doc42/wfs-server-howto.html).
..Tom
> >From: "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca>
> >To: "ANDY CANFIELD"
> ><andy_canfield at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
> >Subject: RE: [UMN_MAPSERVER-USERS] Mapserver CGI or C API question
> >Date: Fri, 29 Oct 2004 17:13:12 -0400
> > > Sent: Friday, 29 October, 2004 17:06
> > > Subject: [UMN_MAPSERVER-USERS] Mapserver CGI or C API question
> > > For anyone who may know,
> > > I am still working on my wireless app for using
> Mapserver from a
> > > Nextel phone. So far so good except I'm starting to run into some
> > > things I don't think the CGI was designed to do. At least not per
> > > the docs. Specifically I need search functionality. I want to be
> > > able to pass in a layer, an attribute and a value to
> search for and
> > > get back the bounding rectangle of all the features returned. I'm
> > > pretty sure the CGI won't do that. Correct me if I'm wrong so I
> > > don't waste time please. So what I'd like to do is write
> my own CGI
> > > that does return this info. So these are my questions:
> >This sounds like a job for a MapServer OGC:WFS GetFeature
> request with
> >filter, i.e.:
> >http://host/cgi-bin/mapserv?map=[mapfile]&version=1.0.0&servi
ce=WFS&req
>u
>est=GetFeature&typename=[layername]&filter<Filter><PropertyIsEqualTo><P
r
>opertyName>[field_name]</PropertyName><Literal>[attribute_value]</Liter
>opertyName>a
>l></PropertyIsEqualTo></Filter>&
>(fill in values in "[]" with your own).
>By definition, this will returned to you all matching features encoded
>as a GML (XML) document. The opening information of this document will
>provided the bounding box of all features returned.
>You can have some middleware which connects to the WFS, makes the
>request, then processes the info accordingly.
>Hope this helps.
>..Tom
> > When you search a layer using mapserver's C api and it is searching
> > a shapefile and you want to search the whole shapefile regardless of
> > bounds is there any special searching that goes on or is it a
> > straight loop through all the records in the shape file looking for
> > matches in the attribute field specified? IE does it load a b-tree
> > in memory and then search the tree or anything like that?
> > Thanks,
> > Andy
> > _________________________________________________________________
> > Express yourself instantly with MSN Messenger! Download today
> > - it's FREE!
> > http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
Get ready for school! Find articles, homework help and more in the Back
to School Guide! http://special.msn.com/network/04backtoschool.armx
