make libgdal.la
Frank Warmerdam
warmerdam at POBOX.COM
Fri Oct 29 18:10:53 EDT 2004
Humberto Cereser Ibanez wrote:
> the make of mapserver-4.2.5, configured as:
> ./configure
> --with-gd=/usr/local
> --with-proj=/usr/local
> --with-gdal=/usr/local/src/gdal-1.2.3/apps/gdal-config
> --with-freetype=/usr/local/bin/freetype-config
> --with-ogr=/usr/local/src/gdal-1.2.3/apps/gdal-config
> --with-xpm=/usr/X11R6
> --with-php=/usr/local/src/php-4.3.8
> --with-pdf=/usr/local
> --with-postgis=/usr/local/pgsql/bin/pg_config
> retorns this error:
> /usr/local/src/gdal-1.2.3/libgdal.la: file not recognized: File format not
> recognized
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
> libgdal.la atached.
> Any sugestion?
Humberto,
I believe you can work around this problem either by configuring and building
GDAL without libtool (the .la file is a pseudo-library file only understood
by libtool), or by acutally doing a "make install" of GDAL into /usr/local,
and using the /usr/local/bin/gdal-config instead of the one "in the source tree".
Generally I advise against trying to use GDAL directly from it's build tree.
While I have tried to make this option work, it is fraught with perils.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
