FastCGI
Skweda O'Bomsawin
sobomsawin at KASSINI.COM
Fri Sep 3 09:09:41 EDT 2004
Hi all!
I just tried to compile Mapserver 4.2.2 for FastCGI without success. I have
installed mod_fcgi and FastCGI lib according to the Mapserver Wiki article.
Is the development of mapserver_fcgi has stopped? Can I expect real
improvements with mapserver_fcgi and PostGIS layers?
Thanks!
Skweda O'Bomsawin
[root at rob mapserver-4.2.2]# make mapserv.fcgi
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DNEED_STRLCAT -DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_SVR -DUSE_WFS_LYR
-DUSE_MING_FLASH -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
-DUSE_PDF -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS -DUSE_THREAD
-I/usr/local/include -I/usr/local/include -I/usr/local/pgsql/include
-I/usr/local/include mapserv_fcgi.c -o mapserv_fcgi.o
mapserv_fcgi.c: In function `writeError':
mapserv_fcgi.c:121: warning: passing arg 1 of `msGetErrorString' makes
pointer from integer without a cast
mapserv_fcgi.c:130: `Item' undeclared (first use in this function)
mapserv_fcgi.c:130: (Each undeclared identifier is reported only once
mapserv_fcgi.c:130: for each function it appears in.)
mapserv_fcgi.c:131: `Value' undeclared (first use in this function)
mapserv_fcgi.c: In function `loadMap':
mapserv_fcgi.c:191: structure has no member named `ParamValues'
mapserv_fcgi.c:192: structure has no member named `ParamValues'
mapserv_fcgi.c:194: structure has no member named `ParamValues'
mapserv_fcgi.c: In function `loadForm':
mapserv_fcgi.c:240: syntax error before ';' token
mapserv_fcgi.c:240: syntax error before ')' token
mapserv_fcgi.c:726: `Item' undeclared (first use in this function)
mapserv_fcgi.c:731: `Value' undeclared (first use in this function)
mapserv_fcgi.c:246: continue statement not within a loop
mapserv_fcgi.c:251: continue statement not within a loop
mapserv_fcgi.c:267: continue statement not within a loop
mapserv_fcgi.c:276: continue statement not within a loop
mapserv_fcgi.c:285: continue statement not within a loop
mapserv_fcgi.c:307: continue statement not within a loop
mapserv_fcgi.c:312: continue statement not within a loop
mapserv_fcgi.c:317: continue statement not within a loop
mapserv_fcgi.c:359: continue statement not within a loop
mapserv_fcgi.c:364: continue statement not within a loop
mapserv_fcgi.c:368: continue statement not within a loop
mapserv_fcgi.c:372: continue statement not within a loop
mapserv_fcgi.c:378: continue statement not within a loop
mapserv_fcgi.c:417: continue statement not within a loop
mapserv_fcgi.c:456: continue statement not within a loop
mapserv_fcgi.c:467: continue statement not within a loop
mapserv_fcgi.c:477: continue statement not within a loop
mapserv_fcgi.c:482: continue statement not within a loop
mapserv_fcgi.c:510: continue statement not within a loop
mapserv_fcgi.c:537: continue statement not within a loop
mapserv_fcgi.c:567: continue statement not within a loop
mapserv_fcgi.c:577: continue statement not within a loop
mapserv_fcgi.c:586: continue statement not within a loop
mapserv_fcgi.c:613: continue statement not within a loop
mapserv_fcgi.c:620: continue statement not within a loop
mapserv_fcgi.c:631: continue statement not within a loop
mapserv_fcgi.c:657: continue statement not within a loop
mapserv_fcgi.c:682: continue statement not within a loop
mapserv_fcgi.c:696: continue statement not within a loop
mapserv_fcgi.c:702: continue statement not within a loop
mapserv_fcgi.c:707: continue statement not within a loop
mapserv_fcgi.c:712: continue statement not within a loop
mapserv_fcgi.c:717: continue statement not within a loop
mapserv_fcgi.c:722: continue statement not within a loop
mapserv_fcgi.c:727: continue statement not within a loop
mapserv_fcgi.c:740: continue statement not within a loop
mapserv_fcgi.c:745: continue statement not within a loop
mapserv_fcgi.c:749: continue statement not within a loop
mapserv_fcgi.c:775: continue statement not within a loop
mapserv_fcgi.c:802: continue statement not within a loop
mapserv_fcgi.c:808: continue statement not within a loop
mapserv_fcgi.c:841: continue statement not within a loop
mapserv_fcgi.c: At top level:
mapserv_fcgi.c:850: syntax error before '&' token
mapserv_fcgi.c:850: warning: type defaults to `int' in declaration of
`regfree'
mapserv_fcgi.c:850: conflicting types for `regfree'
/usr/include/regex.h:570: previous declaration of `regfree'
mapserv_fcgi.c:850: warning: data definition has no type or storage class
mapserv_fcgi.c: In function `main':
mapserv_fcgi.c:1025: syntax error before '=' token
mapserv_fcgi.c:1035: syntax error before ')' token
mapserv_fcgi.c:1042: syntax error before ')' token
mapserv_fcgi.c:1043: structure has no member named `NumParams'
mapserv_fcgi.c:1439: `Item' Untitled 1undeclared (first use in this
function)
mapserv_fcgi.c:1440: `Value' undeclared (first use in this function)
mapserv_fcgi.c:1448: syntax error before numeric constant
mapserv_fcgi.c:1448: warning: type defaults to `int' in declaration of
`exit'
mapserv_fcgi.c:1448: conflicting types for `exit'
/usr/include/stdlib.h:612: previous declaration of `exit'
mapserv_fcgi.c:1448: warning: data definition has no type or storage class
make: *** [mapserv_fcgi.o] Error 1
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.745 / Virus Database: 497 - Release Date: 2004-08-27
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040903/31581f10/attachment.html
