mapserver rasters scale
David Fawcett
David.Fawcett at STATE.MN.US
Tue Sep 7 12:27:50 EDT 2004
I don't believe that this answers your central question, but you may want to take a look at your PROJECTION block.
PROJECTION
"init=esri:27582"
END
should probably read
PROJECTION
"init=epsg:27582"
END
This may not be causing any problems right now, but if you add projection blocks to your layers, I am guessing that you will see an error.
For your primary question, I am guessing that Ed will jump right in. My guess is that MapServer assumes a screen dpi that is not 250. I believe that it is 72, but I am not sure. You will probably have to convert your scale values to work with the default MapServer dpi.
Play with the MINSCALE and MAXSCALE values in your Map file to see where the images swap.
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> Stéphane RIFF <stephane.riff at CERENE.FR> 9/6/2004 3:57:34 AM >>>
Hi all,
I want to display some rasters layers :
first one is 1/250000, 250 dpi
second one is 1/25000, 250 dpi
Here is an extract of my map file :
MAP
UNITS METERS
IMAGETYPE PNG
PROJECTION
"init=esri:27582"
END
LAYER
NAME "250000"
TILEINDEX "../data/250000"
TILEITEM "LOCATION"
TYPE RASTER
STATUS ON
OFFSITE 0 0 0
MINSCALE 25000
MAXSCALE 250000
GROUP "carto"
CLASS
NAME "Fond raster 250000"
END
END
LAYER
NAME "25000"
TILEINDEX "../data/25000"
TILEITEM "LOCATION"
TYPE RASTER
STATUS ON
OFFSITE 0 0 0
MAXSCALE 25000
GROUP "carto"
CLASS
NAME "Fond raster 25000"
END
END
This two layer switch well looking for mapserver scale.
The question i want to ask is why when i open a 1/250000 raster with
GIMP and set the scale to 100%,
it doesn't seem to correspond with what i see in mapserver at scale 250000.
In other words, if mapserver scale is 250000, does it means that the
view is at 1/250000 sacle???
I hope my question is understandable
Thanks
