internal server error 500
Bart van den Eijnden
bartvde at XS4ALL.NL
Thu Sep 9 05:16:06 EDT 2004
the bug report is a Chameleon bug report. Are you using Chameleon?
Can you run ogrinfo on your shapefile? Maybe it is a 3D shapefile which
Mapserver might crash on. Which Mapserver version are you using?
Is your shapefile in lat/lon (WGS84)? Check the extent of your map file
with the extent of your shapefile (can also be done using ogrinfo). First
start simple without PROJECTION definitions.
Best regards,
Bart
> Hi All!
> I have a problem with running MapServer perfectly.
> It seems to be working, but if I try to test the example below I get error
> message: 500 - internal server error.
> All the settings seems to be fine. If I change the status from default to
> on, it is working but I can see only a gray rectangle. Not the contents of
> the shapefile, althoug the extents has to be right, because that is the
> original example!. :(
> I found a bug report (http://www.maptools.org/bugzilla/show_bug.cgi?id=620
> ) about extracting shapfiles, do you think that causes my problem also? If
> it is, then how should I fix it?
> Thx:
> Ferenc Speiser
> MAP
> IMAGETYPE PNG
> EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
> SIZE 400 300
> SHAPEPATH "c:\data"
> IMAGECOLOR 240 240 240
> PROJECTION
> "proj=laea"
> "ellps=clrk66"
> "lat_0=45"
> "lon_0=-100"
> # Alternatively, you can specify an EPSG code.
> # "init=epsg:2163"
> END
> # Start of LAYER DEFINITIONS
> LAYER # States polygon layer begins here
> NAME states
> DATA states_ugl
> STATUS default
> TYPE POLYGON
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> COLOR 232 232 232
> OUTLINECOLOR 32 32 32
> END
> END # States polygon layer ends here
> # End of LAYER DEFINITIONS -------------------------------
> END # end of map file/object
> University of Veszprém
> Department of Automation
