show utm geotiff
joerg p
superbla3000 at GMX.NET
Sun Sep 12 10:10:17 EDT 2004
I found another posting, and I think the problem is my map extent:
EXTENT -180 -90 180 90
So it's in latlong format.
How do I write this in UTM actuelly?
I also use:
UNITS dd
Is this ok?
Joerg
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Titus von der Malsburg
Sent: Sonntag, 12. September 2004 14:40
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] show utm geotiff
On Sat, Sep 11, 2004 at 08:14:25PM +0200, joerg p wrote:
> When I test it with the reprojected image and the Projection tag, the
> image is still shown in latlong. Actuelly I can use whatever in the
> Projection definition, but nothing changes...
The projection used to render the map doesn't depend on the projection
of the layers but on the projection you specify for the map. Therefore
you have to define the projection for the layers and the projection for
the map. The latter will be used for rendering.
Titus
