shptree not faster than no index
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Sep 24 09:55:18 EDT 2004
John,
I have tiger data running under mapserver
http://imaptools.com/tiger/
I have about 18-19 GB of data for these maps.
I just leave the data the way it is translated to shapefiles and build
tileindexes and shptree indexes on the everything and it works great! I
wouldn't spend extra time trying to merge data into a single layer
shapefiles.
In your test you found the it was fast and it didn't make a lot of
difference. Unless you are trying to squeeze every ounce of performance
you can out of the setup then you would have to do a bunch of
experimentation to find out what makes it fast or not.
-Steve W.
John Bolster wrote:
> Thanks for the advice. I'll try it this way on the counties. However, when I
> start working with the other files, like roads, water and places, I'm
> dealing with files that are currently broken down by county and each one may
> have anywhere from 3,000 - 30,000 items per file. So that multiplied by
> 3,000 or so counties comes to 9 - 90 million items if I combined each record
> type into one big file each. Would you still suggest combining them in these
> cases, or do you think that gets too large?
> John
>>-----Original Message-----
>>From: ANDY CANFIELD [mailto:andy_canfield at hotmail.com]
>>Sent: Thursday, September 23, 2004 6:51 PM
>>To: jb at NUCOMP.COM; MAPSERVER-USERS at LISTS.UMN.EDU
>>Subject: Re: [UMN_MAPSERVER-USERS] shptree not faster than no index
>>I'd go with the one file of all counties. It's just easier to
>>maintain one
>>file than 3,000. I have at least 50 layers in one of my maps that
>>each layer
>>can have 300,000 to 1,000,000 plus objects in it. Using the shptree to
>>create a .qix file makes these layers incredibly fast. I mean fast as in,
>>you click on the map to zoom or pan, and as fast as your browser
>>can render
>>the map has been updated to reflect that pan or zoom. I think my smallest
>>layer has 1,400 hundred polygons in it. Using the shptree and having one
>>file is way easier than maintaining a single file for each boundary. I
>>honestly don't think the map I'm using could be any faster, it is the
>>browser/desktop rendering speed for me that limits how fast the image
>>changes, so that's really, really fast. Plus if you have 3,000
>>files and are
>>zoomed to an extent where you can see half of them or more that's
>>1,500 or
>>more open and read operations that Mapserver has to execute vice
>>one if you
>>put them all in the same file. My two cents anyway.
>>>From: John Bolster <jb at NUCOMP.COM>
>>>Reply-To: John Bolster <jb at NUCOMP.COM>
>>>To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>Date: Thu, 23 Sep 2004 18:18:46 -0400
>>>Thank you for your quick response.
>>>In terms of the county outlines, do you think that one county
>>per file, and
>>>selecting which files to use with only a tileindex would be
>>faster than all
>>>counties being in one huge file of over 3000 counties and selecting which
>>>counties to draw using a qix index?
>>>Also, does the qix index on the actual tileindex do anything to speed up
>>>the
>>>tileindex?
>>>Thanks,
>>>John
>>>>From: Frank Warmerdam [mailto:warmerdam at pobox.com]
>>>>Sent: Thursday, September 23, 2004 6:13 PM
>>>>To: John Bolster
>>>>Cc: MAPSERVER-USERS at LISTS.UMN.EDU
>>>>John Bolster wrote:
>>>>>Hi all,
>>>>>I'm noticing there doesn't seem to be any difference in speed
>>>>between having
>>>>>*.qix files vs. not having them. I'm wondering if I'm doing this
>>>right.
>>>>>My data is from tiger and is in shapefiles. I'm only dealing with
>>>county
>>>>>outlines right now. They are each in a separate folder, each state's
>>>>>counties are in one state folder. There's a tileindex on
>>them all at
>>>the
>>>>>root of the tree.
>>>>John,
>>>>The impression I get is that you have exactly one county polygon
>>>>per shapefile.
>>>>Is that right? A .qix won't help because it is used to more
>>>>quickly select
>>>>the subset of shapes in a shapefile based on the extents. If you
>>>>only have
>>>>one shape per file then it can't help.
>>>>Of course, the tileindex should allow you to quickly select the county
>>>>files you want. But a more efficient approach would likely
>>be to have
>>>one
>>>>shapefile with a .qix with all your county outlines in it.
>>>>Best regards,
>>>>I set the clouds in motion - turn up | Frank Warmerdam,
>>>>light and sound - activate the windows | http://pobox.com/~warmerdam
>>>>and watch the world go round - Rush | Geospatial
>>Programmer for Rent
>>_________________________________________________________________
>>FREE pop-up blocking with the new MSN Toolbar – get it now!
>>http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
