Problems with Positioning Names from MapInfo TAB file
{Scanned} {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Tue Sep 28 14:20:15 EDT 2004
I had the same problem some weeks ago.
I failed to use auto styling for mapinfo text elements, so i
convert the text to line item and the text is an attribute of the
line element. Then i created a annotation layer in mapserver with
angle auto.
I wrote the program in mapbasic, if you have mapinfo i send it to you.
bye
Zoltan
On Tue, 28 Sep 2004, Bob Bruce wrote:
> Hi:
> I am trying to use a TAB file that has names positioned on blockfaces.
> In the MapInfo ProViewer (a free viewer from MapInfo) I can view the file
> and see the street annotation positioned at the various angles that they run
> along the streets. But when I try and display this in MapServer I only get
> them positioned horizontally. I tried using the LABEL object but it wouldn't
> display them at all so I reverted to the STYLEITEM "AUTO" command and it put
> the labels out but only horizontally.
> Does anyone know how to get MapServer to use the angles stored with the
> text in the file? My map file is included below. The blckface file has both
> lines for blockfaces and text elements in it. Here is some same output from
> the OGRINFO program:
> OGRFeature(ST_VITAL_BONIFACE_BLKFACE):4532
> ID (Integer) = 6152
> Style = PEN(w:1px,c:#d9bb15,id:"mapinfo-pen-2.ogr-pen-0")
> LINESTRING (634272.418 5523967.692,634279.402 5523966.363)
> OGRFeature(ST_VITAL_BONIFACE_BLKFACE):4533
> ID (Integer) = 6209
> Style = LABEL(t:"KINGSTON",a:358.700000,s:15.996744g,c:#000000,p:1,f:"Arial")
> POINT (634312.023 5524049.501)
> OGRFeature(ST_VITAL_BONIFACE_BLKFACE):4534
> ID (Integer) = 6498
> LINESTRING (634214.639 5524099.705,634218.473 5524099.606,634229.861
> 5524098.786)
> OGRFeature(ST_VITAL_BONIFACE_BLKFACE):4535
> ID (Integer) = 6640
> LINESTRING (634211.638 5523974.631,634214.078 5523973.711,634223.050
> 5523971.702,634226.793 552397
> 1.362)
> OGRFeature(ST_VITAL_BONIFACE_BLKFACE):4536
> ID (Integer) = 1893
> Style = LABEL(t:"VICTORIA
> GR",a:333.600000,s:15.996744g,c:#000000,p:1,f:"Arial")
> POINT (634252.281 5522621.452)
> here you can see both text and lines.
> thanks,
> Bob Bruce
> NAME St_Boniface_Vital_s2ex1
> # EXTENT 632862.444326 5510719.468992 642031.781954 5529899.634924
> # EXTENT 633000 5521000 641000 5528000
> EXTENT 633850 5525850 635050 5527050
> SIZE 400 400
> LAYER # Polling Subdivision
> NAME "Polling Subdivision"
> CONNECTIONTYPE OGR
> CONNECTION
> "C:/Apache/htdocs/MapserverTutorial/StBonifaceStVital/St_Boniface_Vital_Data/PollingSubDivision.tab"
> STATUS DEFAULT
> TYPE POLYGON
> CLASS # Polling Subdivision <= 250
> NAME "Polling Subdivision <= 250"
> EXPRESSION ([Population] <= 250)
> COLOR 255 204 204
> OUTLINECOLOR 0 0 0
> END # end of Whole DLS Parcel class object
> CLASS # Polling Subdivision <= 500
> NAME "Polling Subdivision <= 500"
> EXPRESSION ([Population] <= 500)
> COLOR 250 128 128
> OUTLINECOLOR 0 0 0
> END # end of Part DLS Parcel class object
> CLASS # Polling Subdivision <= 750
> NAME "Polling Subdivision <= 750"
> EXPRESSION ([Population] <= 750)
> COLOR 255 40 40
> OUTLINECOLOR 0 0 0
> CLASS # Polling Subdivision <= 1000
> NAME "Polling Subdivision <= 1000"
> EXPRESSION ([Population] <= 1000)
> COLOR 200 0 0
> OUTLINECOLOR 0 0 0
> END # end of layer object
> LAYER # Street Lines
> NAME "Street Lines"
> CONNECTIONTYPE OGR
> CONNECTION
> "C:/Apache/htdocs/MapserverTutorial/StBonifaceStVital/St_Boniface_Vital_Data/st_Vital_Boniface_blkface.tab"
> STATUS DEFAULT
> TYPE LINE
> # STYLEITEM "AUTO"
> CLASS
> STYLE
> # COLOR 255 146 36
> COLOR 255 255 0
> END
> END
> END
> LAYER # Street Names
> NAME "Street Names"
> CONNECTIONTYPE OGR
> CONNECTION
> STATUS DEFAULT
> TYPE ANNOTATION
> STYLEITEM "AUTO"
> CLASS
> # LABEL
> # ANGLE AUTO
> # COLOR 0 0 0
> # COLOR 43 255 177
> # SIZE SMALL
> # TYPE BITMAP
> # END
> END
> END
> END # end of map file
