Help In Accessing/Displaying Mapscripts
Ike Brian
ikebrian at YAHOO.COM
Wed Sep 29 00:02:12 EDT 2004
Hello,
I have PHP/Mapscript *.phtml files but dont know how to access them.These data are from the mapserver web they are already programmed files but want to know how to access *.phtml files.These are the USA files from http://www.mobilegeographics.com/mapserver/
Could anyone in how I can display the map using these files.I am only used to html files.
Skweda O'Bomsawin <sobomsawin at KASSINI.COM> wrote:
Ike,
To get the Mapserver demo working, you must at least:
1- Have a working installation of Apache with CGI support
2- Have a working installation of Mapserver CGI
3- Change variables of the Map file (SHAPEPATH, TEMPLATE and WEB block particularly) according to your system
4- Change variables of the HTML files according to your system
You can verify your Mapserver CGI installation by sending a test URL to your server (see the doc from Mapserver web site). I recommend you take a look at this tutorial which will guide you through the installation and testing process:
http://terrasip.gis.umn.edu/projects/tutorial/
Otherwise, you can use the DMSolutions Maplab product:
http://www.dmsolutions.ca/techserv/maplab.html
Best regards,
Skweda O'Bomsawin
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de Ike Brian
Envoyé : 25 septembre 2004 21:19
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] Query not showing Map/Scale/Legend
Thank you very much for the reply.I have downloaded the demo as u said and have followd all the necessary steps.
When I clicked on intialise the page the opened did not show the following
· the map
· legend
· scale
But all other things showed up.I would like to know if there is something else that I should do to show up the above mentioned objects.
I think that image type is the problem.Hoping to hear from you.
Isaac
done as you said.
David Fawcett <David.Fawcett at state.mn.us> wrote:
Ike,
I recommend that you downloat the demo and get that up and running.
