Layers Symbology {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Wed Sep 29 17:51:53 EDT 2004
You have to define symbol set, you can put it into a separate file or
you cen define symbols in the map file. Usually the separate file is
prefered.
symbol file (symbols.sym)
SYMBOLSET
SYMBOL # standard cicular brush
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
SYMBOL # cross hatching
NAME 'fill45'
TYPE VECTOR
TRANSPARENT 0
POINTS
0 1
1 0
END
END
# end of symbol file
map file
LAYER # cross hatched polygons
NAME 'a_polygon_layer'
CLASS
COLOR 60 60 60
OUTLINECOLOR 0 0 0
SYMBOL 'fill45'
SIZE 3
END
END
LAYER # thick lines
NAME 'a_line_layer'
CLASS
SYMBOL 'circle'
SIZE 3
COLOR 255 0 0
END
END
For more info check mapserver wiki
Bye
Zoltan
On Wed, 29 Sep 2004, Pierre RELLA wrote:
> Hi,
> I have two questions:
> -In a vector layer, line or polygon type,is it possible to thicken the
> line or the outline?
> -In vector lines, polygon type, instead of full polygons i want to have
> hatching polygons
