web coverage server
Norman Barker
nbarker at RSINC.COM
Fri Apr 1 09:27:28 EST 2005
having used MapServer WCS for DEM data (fantastic, thanks for the help), I am looking to use the WCS
for temporal data too.
In particular I was thinking of using the WCS to serve netCDF data, filtering on temporal dimensions,
and dataset parameters (not doing any geographic subset as yet).
My questions are;
1) GDAL seems to have problems with netCDF, would I be better to translate to geotiff where each band represents
a dataset parameter?
2) Has anyone done something similar?
Quoting from the WCS howto
Only spatial, simple temporal and radiometric band subsetting is possible with the current implementation
Does that mean I would have to convert to geotiff to support querying by dataset parameter, since each band could represent a different
parameter?
Any help on the time dimensions would be appreciated.
Are there any examples (however small) I could look at.
Many thanks,
Norman Barker
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050401/1523b962/attachment.html
