pixmap symbols from mapscript ?
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Apr 1 11:52:46 EST 2005
Attila,
The SWIG/mapscript ver 4.4 document gives you access the the symbolObj
and you can change the imagepath property. With that you should be able
to have a symbolset file with template symbols in it and then
populate/change the imagepaths to point to the images you want to use
for a given map draw.
-Steve W
Attila Csipa wrote:
> I'm having difficulties using pixmap symbol from mapscript (current CVS
> version), I wonder if someone had experience with a similar problem ?
> I wanted to have rotated pixmap (bitmap) symbols on my map, however AFAIK
> mapserver does not support rotated symbols. I thought I could make prerotated
> bitmaps which I would put in symbolset and use classes to show the proper
> symbol. However, this needed the increase of the MS_MAXSYMBOLS define (I
> tried with 1000) after which mapserver would hang indefinitely if the
> symbolset itself contained somewhere over 300 symbols (I also tried playing
> with MS_MAXSTYLES and MS_MAXCLASSES in map.h to no avail). Alternatively I
> wanted to generate the symbols dynamically from mapscript, however looking at
> the docs I see no reference to the possibility of creating bitmap symbols
> (even though the MS_SYMBOL_PIXMAP constant does exist). As a last resort I
> tried to generate a temporary symbolset file which contained only the needed
> symbols for a certain map extent and load it with $map->setsymbolset(), but
> regardless of the number of symbols it contained, it hang, but ONLY if the
> symbols defined inside were of PIXMAP type. I did not managed to dig up
> anything relevant in the list archives. Any ideas ?
