PostGIS Layer mapfile def issue
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Fri Apr 1 15:10:07 EST 2005
I have a PostGIS layer with which I'd like to serve via WMS/WFS. The
PostGIS instance has two tables as LAYER defs. For one of the tables
(as def'd below in mapfile) as a LAYER object, I'd like to include
fields from another table. I have a one-to-many relationship which MAY
occur from one table to another (in the case below, service_endpoints is
the one vs. service_resources is the many).
Here's the mapfile snippet:
LAYER
NAME "service_resources"
STATUS ON
CONNECTIONTYPE postgis
CONNECTION "user=postgres dbname=devgeodb"
DATA "the_geom from (select service_endpoints.organization as
organization,service_endpoints.endpoint_getresource as
endpoint_getresource from service_resources left join service_endpoints
on service_resources.service_id = service_endpoints.service_id) as t
using unique resource_id"
TYPE POLYGON
DUMP TRUE
HEADER "service_resources_query_header.html"
TEMPLATE "service_resources_query_body.html"
TOLERANCE 30
METADATA
"ows_title" "Service Resources"
"ows_abstract" "Service Resources"
"ows_keywordlist" "environment,ogc,cgdi"
"wms_opaque" "0"
"ows_extent" "-141.089000 36.392987 -52.089000 89.784987"
"ows_metadataurl_type" "FGDC"
"wms_metadataurl_format" "text/html"
"ows_metadataurl_href" "http://devgeo.cciw.ca/index.html"
"wms_dataurl_format" "text/html"
"wms_dataurl_href" "http://devgeo.cciw.ca/index.html"
"wfs_metadataurl_format" "TXT"
"gml_include_items" "all"
END
PROJECTION
"init=epsg:4326"
END
CLASS
NAME "Service Resources"
COLOR 0 0 255
OUTLINECOLOR 0 0 0
SYMBOL "upwarddiagonalfill"
SIZE 1
END
END
When I run a WFS GetFeature request, the only features returned are
those which have one-to-one relationships. The one-to-many related
values are not returned. My service_resources.resource_id is unique.
Which leads me to believe that my DATA declaration is off somewhere.
Any advice?
Thanks
..Tom
