No anti-aliasing for cartoline symbol?
William K
woklist at CHARTER.NET
Fri Apr 1 15:37:09 EST 2005
Don't know what to say. For the record, I build MapServer from source,
v4.4.1 now (I can't remember when I started using cartolines), on Mac
OS X. I just realized that you say 4.5 - is that the CVS dev version?
Maybe some new change broke cartoline antialiasing.
On Apr 1, 2005, at 1:43 PM, James Sohr wrote:
> Thanks for the suggestions, I really appreciate them.
> So far, no worky.
> I removed the 'antialias true' from the symbol file, no change.
> I removed the 'antialias true' from the style area, no change.
> I re-added the 'anti-alias true' to the style area, and set the
> linejoin
> type in the symbol file to round, the linecap type to round, and
> linejoinmaxsize to 3... and the edges of my lines and corners got
> rounder,
> but no change in the aliasing.
> I then removed all layers except for the layer in question, removed the
> background color set for the whole map, removed the projection
> settings,
> removed all the labels, so that I was down to a simple single layer and
> there still is no change in the aliasing.
> I even tried to get antialiased single-pixel width lines to work by not
> using any symbol reference or size parameter:
> MAP
> LAYER
> TYPE LINE
> DATA "myshapefile.dbf"
> NAME "roads"
> COLOR 0 0 0
> STYLE
> ANTIALIAS TRUE
> END
> END
> END
> Even this did not work-- my single pixel line was still very much
> aliased!
> In the archives, I noticed at least one other fellow could not get the
> single-pixel line anti-aliasing to work, and wonder if this issue is
> related to the cartoline symbols not being anti-aliased.
> Any other ideas out there? Could this possibly be some sort of bug?
William Kyngesburye <kyngchaos at charter.net>
http://webpages.charter.net/kyngchaos/
All generalizations are dangerous, even this one.
