Drawing the point on the map and adding it to shapefile
Giridhar Manepalli
gmanepal at GMAIL.COM
Fri Apr 1 19:09:55 EST 2005
Hello Till,
Recently there were few posts on how to convert a click on the map to
a coordinate. I am infact looking out for one which you suggested. Can
you provide me with the details anout your code and link to the
example.
Thanks,
Giridhar
> Dear Gambin,
> we do this by using UMN as WMS and write the click-coordinate from a
> featureinfo request back to a PostGIS database.
> You are able to edit the attributes and upload images, etc.
> If this helps, I can send you the code and a link to an example,
> Till
> Mit freundlichen Grüssen aus Bonn,
> Till Adams
> * AmeiN! ArcGIS Map-Export-2-UMN *
> * AmeiN! Workshop 11. Mai 2005 *
> * http://www.terrestris.de *
> Dipl. Geogr. Till Adams
> terrestris, Paulsen&Adams GbR
> Siemensstr. 8 * 53121 Bonn
> Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
> info at terrestris.de * www.terrestris.de
