new user problem
Giridhar Manepalli
gmanepal at GMAIL.COM
Sat Apr 2 11:33:11 EST 2005
Hello,
IMAGEURL should not have a value which is a file-path. It should be a
relative address from cgi-bin directory.
If cgi-bin points to rosia in your case, then IMAGEURL should point to "tmp".
If you still get the error, follow up this message with your cgi-bin directory.
Regards,
Giridhar
On Apr 2, 2005 9:43 AM, Ferencik Ioan <ferencik.ioan at personal.ro> wrote:
> I modified IMAGEURL to /tmp/ and still the same:))
> I attached a screenshot I see in Firefox instead map
> > Ferencik -
> > You didn't follow the instructions I gave you the first time you asked.
> > You changed your IMAGEURL from a URL to a file path, and that's why you
> > see the path to the PNG file. Your IMAGEURL should not have been
> > changed from the original value you were using when you first asked the
> > question - it should be just "tmp".
> > The URL for a MapServer image in browse mode is created by adding the
> > filename of the generated file to the string in the IMAGEURL statement.
> > If you modify the IMAGEURL, you'll see that the URL to the PNG file in
> > the generated HTML output changes. Just chang the IMAGEURL until the
> > generated URL is correct and pointing to the images.
> > You are getting an "error message" - the broken link icon is telling you
> > that the file can't be found!
> > - Ed
> > Ed McNierney
> > President and Chief Mapmaker
> > TopoZone.com / Maps a la carte, Inc.
> > 73 Princeton Street, Suite 305
> > North Chelmsford, MA 01863
> > Phone: +1 (978) 251-4242
> > Fax: +1 (978) 251-1396
> > ed at topozone.com
> > -----Original Message-----
> > From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> > Behalf Of Ferencik Ioan
> > Sent: Saturday, April 02, 2005 5:52 AM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: [UMN_MAPSERVER-USERS] new user problem
> > Hi list,
> > i still have some problems with mapserver. I created a mapfile wich I
> > can in map mode with IE6 or Firefox. Though, in browse mode i see only
> > a blank picture, instead of PNG file itself I see a path to that PNG
> > file. When I click on map it doesn't give me any error it seems taht the
> > aplication is capable of panning. I do not understand what is happenning
> > because I don't receive any error message.
> > I use folowing map file:
> > MAP
> > IMAGETYPE PNG24
> > #EXTENT 349932 529491 358227 537108 # extent alba
> > EXTENT 388605 583929 398798 590500
> > FONTSET "fonts/fonts.list"
> > SIZE 1000 1000
> > SHAPEPATH "date"
> > IMAGECOLOR 255 255 255
> > TEMPLATEPATTERN "index"
> > NAME "raster"
> > PROJECTION
> > "init=epsg:31700"
> > END
> > # Start of LAYER DEFINITIONS
> > LAYER # layer de tip raster
> > NAME dem
> > DATA "cluj.tif"
> > TYPE RASTER
> > PROJECTION
> > "init=epsg:31700"
> > END
> > STATUS default
> > PROCESSING "BANDS=1,2,3"
> > END #--sfarsit layer de tip raster
> > LAYER # States polygon layer begins here
> > NAME test
> > DATA strazi
> > STATUS DEFAULT
> > TYPE LINE
> > PROJECTION
> > "init=epsg:31700"
> > END
> > #CLASSITEM "NAME"
> > LABELITEM "NAME"
> > CLASS
> > COLOR 255 255 255
> > LABEL
> > COLOR 0 0 0
> > TYPE TRUETYPE
> > FONT arial
> > SIZE 8
> > POSITION LL
> > PARTIALS true
> > MINDISTANCE 300
> > #BUFFER 4
> > END
> > END
> > END
> > # End of LAYER DEFINITIONS -------------------------------
> > WEB
> > IMAGEPATH "c:\ms4w\rosia\tmp\"
> > IMAGEURL "c:\ms4w\rosia\tmp\"
> > TEMPLATE 'index.html'
> > LOG mslog.txt
> > END
> > END # end of map file/object
> > and this is my template file:
> > <!-- MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> > OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
> > SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> > SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR
> > INPUT=GDAL INPUT=SHAPEFILE --> <html> <title> Aplicatie
> > Mapserver</title> <body> <FORM action="/cgi-bin/mapserv.exe"
> > method="GET" >
> > <input type="hidden" name="map" value="c:\ms4w\rosia\raster.map" >
> > <input type="hidden" name="imgext" value="368891.738000 604053.336000
> > 379084.738000 614246.336000">
> > <input type="hidden" name="imgxy" value="500 500">
> > <input type="hidden" name="zoom" value="1">
> > <input type="hidden" name="mode" value="browse">
> > <p align="center" style="border: 1px dashed red; "> Aplicatie
> > Mapserver</p><hr>
> > <div align="center" style="border: 1px dashed red; width: 502px;
> > height:
> > 502px; ">
> > <input type="image" name="img"
> > value="c:\ms4w\rosia\tmp\raster11124387134088.png" width="500"
> > height="500">
> > </div>
> > </FORM>
> > </body>
> > </html>
> > Can anyone give me a hint?
> > Thanks in advance
> > _____________________________________________
> > Castiga peste 1000 de premii cu Wella Design!
> > http://wella.boom.ro
