new user problem
Ed McNierney
ed at TOPOZONE.COM
Sat Apr 2 14:24:04 EST 2005
Ferencik -
I am certain that the image URL in the generated HTML out is NOT "still
the same". Take a look at what it is, and adjust it appropriately. I
believe I recommended below that you change it to "tmp", not to "/tmp/".
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Ferencik Ioan
Sent: Saturday, April 02, 2005 9:43 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] new user problem
I modified IMAGEURL to /tmp/ and still the same:)) I attached a
screenshot I see in Firefox instead map
> Ferencik -
> You didn't follow the instructions I gave you the first time you
asked.
> You changed your IMAGEURL from a URL to a file path, and that's why
> you see the path to the PNG file. Your IMAGEURL should not have been
> changed from the original value you were using when you first asked
> the question - it should be just "tmp".
> The URL for a MapServer image in browse mode is created by adding the
> filename of the generated file to the string in the IMAGEURL
statement.
> If you modify the IMAGEURL, you'll see that the URL to the PNG file in
> the generated HTML output changes. Just chang the IMAGEURL until the
> generated URL is correct and pointing to the images.
> You are getting an "error message" - the broken link icon is telling
> you that the file can't be found!
> - Ed
> Ed McNierney
> ed at topozone.com
> On Behalf Of Ferencik Ioan
> Sent: Saturday, April 02, 2005 5:52 AM
> Subject: [UMN_MAPSERVER-USERS] new user problem
> Hi list,
> i still have some problems with mapserver. I created a mapfile wich I
> can in map mode with IE6 or Firefox. Though, in browse mode i see only
> a blank picture, instead of PNG file itself I see a path to that PNG
> file. When I click on map it doesn't give me any error it seems taht
> the aplication is capable of panning. I do not understand what is
> happenning because I don't receive any error message.
> I use folowing map file:
> MAP
> IMAGETYPE PNG24
> #EXTENT 349932 529491 358227 537108 # extent alba
> EXTENT 388605 583929 398798 590500
> FONTSET "fonts/fonts.list"
> SIZE 1000 1000
> SHAPEPATH "date"
> IMAGECOLOR 255 255 255
> TEMPLATEPATTERN "index"
> NAME "raster"
> PROJECTION
> "init=epsg:31700"
> END
> # Start of LAYER DEFINITIONS
> LAYER # layer de tip raster
> NAME dem
> DATA "cluj.tif"
> TYPE RASTER
> PROJECTION
> "init=epsg:31700"
> END
> STATUS default
> PROCESSING "BANDS=1,2,3"
> END #--sfarsit layer de tip raster
> LAYER # States polygon layer begins here
> NAME test
> DATA strazi
> STATUS DEFAULT
> TYPE LINE
> PROJECTION
> "init=epsg:31700"
> END
> #CLASSITEM "NAME"
> LABELITEM "NAME"
> CLASS
> COLOR 255 255 255
> LABEL
> COLOR 0 0 0
> TYPE TRUETYPE
> FONT arial
> SIZE 8
> POSITION LL
> PARTIALS true
> MINDISTANCE 300
> #BUFFER 4
> END
> END
> END
> # End of LAYER DEFINITIONS -------------------------------
> WEB
> IMAGEPATH "c:\ms4w\rosia\tmp\"
> IMAGEURL "c:\ms4w\rosia\tmp\"
> TEMPLATE 'index.html'
> LOG mslog.txt
> END
> END # end of map file/object
> and this is my template file:
> <!-- MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER >
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR >
INPUT=GDAL INPUT=SHAPEFILE --> <html> <title> Aplicatie
> Mapserver</title> <body> <FORM action="/cgi-bin/mapserv.exe"
> method="GET" >
> <input type="hidden" name="map" value="c:\ms4w\rosia\raster.map" >
> <input type="hidden" name="imgext" value="368891.738000
> 604053.336000 379084.738000 614246.336000">
> <input type="hidden" name="imgxy" value="500 500">
> <input type="hidden" name="zoom" value="1">
> <input type="hidden" name="mode" value="browse">
> <p align="center" style="border: 1px dashed red; "> Aplicatie
> Mapserver</p><hr>
> <div align="center" style="border: 1px dashed red; width: 502px;
> height:
> 502px; ">
> <input type="image" name="img"
> value="c:\ms4w\rosia\tmp\raster11124387134088.png" width="500"
> height="500">
> </div>
> </FORM>
> </body>
> </html>
> Can anyone give me a hint?
> Thanks in advance
> _____________________________________________
> Castiga peste 1000 de premii cu Wella Design!
> http://wella.boom.ro
