WMS GetCapabilities problem
    Wouter Schaubroeck
    wouter.schaubroeck at GMAIL.COM
    Sun Apr  3 13:45:27 PDT 2005
Hi all,
I'm using the ms4w application you all know. I worked myself through the
tutorial, and now i want to set up my own WMS Server. Therefor i used
example 1.7. But when i want to test my WMS Server and perform a
GetCapabilities request, Firefox is offering me the mapserv.exe file, in
stead of an XML document. What am i doing wrong?
This is my hyperlink with the request:
http://192.168.2.3/cgi-bin/mapserv.exe?map=c:/ms4w/apache/htdocs/mapservertutorial/example1-7.map&SERVICE=WMS&VERSION1.1.1&REQUEST=GetCapabilities
<http://192.168.2.3/cgi-bin/mapserv.exe?map=c:/ms4w/apache/htdocs/mapservertutorial/example1-7.map&SERVICE=WMS&VERSION1.1.1&REQUEST=GetCapabilities>
This is my MAP file:
MAP
NAME           EX1.7_
IMAGETYPE      PNG24
#EXTENT        201621.496941 -294488.285333 1425518.020722 498254.511514
# LAEA
EXTENT         -97.5 41.619778 -82.122902 49.38562 # Geographic
SIZE           400 300
SHAPEPATH      "c:\ms4w\apache\htdocs\mapservertutorial\data"
SYMBOLSET
"c:\ms4w\apache\htdocs\mapservertutorial\symbols\symbols35.sym"
FONTSET        "c:\ms4w\apache\htdocs\mapservertutorial\fonts\fonts.list"
WEB
  IMAGEPATH 'c:\tmp\'
  IMAGEURL  '\tmp\'
    METADATA
        "wms_title"                    "WMS_Test"
        "wms_onlineresource"
"http://192.168.2.2/cgi-bin/mapserv.exe?map=c:\ms4w\apache\htdocs\mapservertutorial\example1-7.map&"
        "wms_srs"                    "EPSG:2136"
    END
END
PROJECTION
#  "proj=laea"
#  "ellps=clrk66"
#  "lat_0=45"
#  "lon_0=-100"
# Alternatively, you can specify an EPSG code.
 "init=epsg:2163"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # States polygon layer begins here
  NAME         states
  DATA         states_ugl
  STATUS       OFF
  TYPE         POLYGON
  PROJECTION
    "init=epsg:4326"
  END
    METADATA
        "wms_title"        "States Polygon"
        "wms_srs"        "epsg:4326"
    END
  CLASSITEM    "CLASS"
  CLASS
    EXPRESSION 'land'
    SYMBOL     0
    COLOR      232 232 232
  END
END # States polygon layer ends here
LAYER # MODIS raster layer begins here
  NAME         modis
  DATA         "raster\mod09a12003161_ugl_ll_8bit.tif"
  STATUS       OFF
  TYPE         RASTER
  PROCESSING   "BANDS=1,2,3"
  OFFSITE      71 74 65
#  PROJECTION
#    "init=epsg:4326"
#  END
END # MODIS raster layer ends here
LAYER # LandSat WMS map from JPL (or from USGS)
  NAME         LandSat
  TYPE         RASTER
  OFFSITE      0 0 0
  STATUS       DEFAULT
  CONNECTIONTYPE     WMS
  #CONNECTION
"http://wms.jpl.nasa.gov/wms.cgi?REQUEST=map&LAYERS=us_landsat7&STYLES=&FORMAT=png&TRANSPARENT=true"
#verwijder de 1!!
  CONNECTION
"http://gisdata.usgs.net/servlet/com.esri.wms.Esrimap?ServiceName=USGS_WMS_LANDSAT7&VERSION=1.0.0&REQUEST=map&Layers=LANDSAT7&SRS=EPSG:4326&REASPECT=false&Format=png&"
  METADATA
    "wms_title" "LandSat"
    "wms_name" "us_landsat7"
    "wms_server_version" "1.0.0"
    "wms_format" "image/png"
    #"wms_title" "US_Landsat7"
    # "wms_srs" "epsg:4326"
    # "wms_connectiontimeout" "1000"
  END
#  PROJECTION
#    "init=epsg:4326"
#  END
END # LandSat WMS image ends here
LAYER # States line layer begins here
  NAME         states
  DATA         states_ugl
  STATUS       DEFAULT
  TYPE         LINE
#  PROJECTION
#    "init=epsg:4326"
#  END
  CLASSITEM    "CLASS"
  CLASS
    EXPRESSION 'land'
    SYMBOL     'line5'
    COLOR      64 64 64
    SIZE       1
  END
END # States line layer ends here
LAYER # States label layer begins here
  NAME         states
  DATA         states_ugl
  STATUS       DEFAULT
  TYPE         ANNOTATION
#  PROJECTION
#    "init=epsg:4326"
#  END
  CLASSITEM    "CLASS"
  LABELITEM    "STATE"
  CLASS
    EXPRESSION 'land'
    COLOR      -1 -1 -1
    LABEL
      COLOR    255 255 255
      TYPE     TRUETYPE
      FONT     arial-bold
      SIZE     12
      ANTIALIAS    TRUE
      POSITION     CL
      PARTIALS     FALSE
      MINDISTANCE  300
      BUFFER       4
    END # end of label
  END # end of class
END # States label layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050403/825e65fe/attachment.htm>
More information about the MapServer-users
