class expression on date field
Stéphane RIFF
stephane.riff at CERENE.FR
Mon Apr 4 04:26:02 EDT 2005
I solve the problem :)
In fact if you make some classes in a layer with a template
when you query this layer the expression filter
doesn't apply to the query.
You must add template to each classes and remove it from your layer.
Thanks
Stéphane RIFF wrote:
> Hi,
> I'm using postgis to render some GPS points, it works quite fine now...
> The problem i have is i want to create some classes in a layer like :
> LAYER
> DATA geom from <table>
> CALSSITEM "gps_date"
> TEMPLATE "dummy"
> CLASS
> EXPRESSION "/2005-04-04.*/"
> END
> END
> I thought that this expression give all points of a day but it
> seems that some other points are returns too. I saw it because
> when i do a queryByPoint i see that gps date is older than my expression
> date.....
> Does this layer def seems good ?
> Another question :
> When i do a queryByPoint, i can query some point that are not shown on
> the map.
> I don't know how it's possible but maybe i have to add a template on each
> classes but not in the layer ?
> Will try ( i just think of it)
> Thanks
