Autodesk support
Francesco Sozzi
fsozzi at INTERCAD.CH
Mon Apr 4 12:31:51 EDT 2005
Hi all,
just a brief note to tell that the possibility to read dwg files should be
highly desiderable, as this format is very used.
The conversion from dwg to shp in many cases is not an option, because it
requires too much work (I refer to the many users that have hundred dwg
files with frequents updates). In these cases Mapserver can't be used.
Best regards
Francesco
----- Original Message -----
From: "Bart van den Eijnden" <bartvde at XS4ALL.NL>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, April 01, 2005 10:02 PM
Subject: Re: [UMN_MAPSERVER-USERS] Autodesk support
> Hi Tom,
> currently not that I know of. Ofcourse there have been wishes for this for
> a long time.
> Your only option would be experimenting with Mapserver FastCGI in
> combination with FMEObjects.
> Best regards,
> Bart
> On Fri, 1 Apr 2005 14:52:31 -0500, Kralidis,Tom [Burlington]
> <Tom.Kralidis at EC.GC.CA> wrote:
>> Hi,
>> Is there any support in MapServer for Autodesk vector formats?
>> Thanks
>> ..Tom
>> Tom Kralidis
>> Senior Systems Scientist
>> Environment Canada
>> Tel: +01-905-336-4409
>> http://www.ec.gc.ca/
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
