Mapscript error when PHP compiled with GD support
Camden Daily
cdaily at GMAIL.COM
Mon Apr 4 12:42:35 PDT 2005
I hadn't realized that about PHP using it's own version of GD. That
sounds like it could very well be the issue. However, now I'm having
issues even compiling PHP with GD. For some reason, it wants to find
gd.h and libgd.so in the same directory (even though one's under
/usr/lib and the other's in /usr/include) If I point -with-gd= to
one, it balks on not finding the other.
Gotta love linux sometimes. I even tried adding an --includedir
option for the other one, but no luck. Guess I've gotta hack the
makefile now.
I'll let you know if things clear up once I can get things to compile nicely.
-Camden
> Wiser men than me have said previously on this list that if you want to
> build both PHP and PHP/Mapscript with GD, you better make sure you
> build them both with the *same* GD. Otherwise strange things like the
> one you are seeing can happen.
> So, if you have (for instance) installed GD into /usr/local and used
> that GD for building php_mapscript, then you also need to build php
> using --with-gd=/usr/local. By simply using --with-gd you get a version
> of GD that is included with PHP, which is likely different from your
> installed version of GD.
> HTH,
> Toomas
More information about the MapServer-users
