MySQL and mapfile
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Apr 5 15:06:34 EDT 2005
Jeff,
In short story is, do:
find /path/to/data -name "*.shp" -exec shptree {} \;
on Linux will add a spatial index file to each of your shapefiles which
will greatly speed up mapserver.
-Steve W.
Jeff Portwine wrote:
> You don't happen to have a link to that post about .qix files do you? I
> have no idea what they are about, but I know that most of my shapefiles
> don't have them. If I can create them and speed up my application I'd
> love
> to do so :)
> -Jeff
> ----- Original Message -----
> From: "Don Deskins" <dldeskins at GMAIL.COM>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Tuesday, April 05, 2005 2:23 PM
> Subject: Re: [UMN_MAPSERVER-USERS] MySQL and mapfile
>> Steve,
>> Thank you very much for your reply. I am sorry to say that I didn't
>> know there was a ".qix" file. With my database background, I assumed
>> that an indexed database field would be faster than a flat file. Of
>> course, that is correct if the flat file is not index. I searched
>> through the archives and found out what a .qix file was all about. I
>> created one for each of my shapes and sped up download time by 50%.
>> Now on to tiling the shp files :)
>> Thanks again
>> On Apr 5, 2005 12:11 PM, Stephen Woodbridge <woodbri at swoodbridge.com>
>> wrote:
>>> Don Deskins wrote:
>>> > Hello,
>>> > Again, I am new to mapserver. I have finally gotten my map to display
>>> > properly but it is very slow, so I am interested in getting all of the
>>> > data
>>> > into a database (MySQL).
>>> Shapefiles are very fast if they are set up correctly and indexed. You
>>> would be wise to understand and resolve the performance issues before
>>> moving the data to mysql as it is not likely to be faster.
>>> For example do all you shapefiles have *.qix file?
>>> How is your mapfile structured? Are you trying to draw too much detail
>>> at larger zoom values?
>>> When is it slow? Zoomed in or zoomed out or both. If we had some more
>>> information we might be able to help you resolve the performance issues.
>>> Understanding these issues might also help you when you get the data
>>> loaded into mygis.
>>> -Steve W.
>>> > I have data (in .shp, .dbf, and .shx files) that I have converted
>>> using
>>> > mygisimport. This produce an sql file which I imported into the MySql
>>> > db.
>>> > I am now having trouble accessing this data with the mapfile. Here is
>>> > what
>>> > I have:
>>> > LAYER
>>> > NAME "SCAP_Cert2004_ParcelsUTM16M"
>>> > CONNECTIONTYPE mygis
>>> > CONNECTION "host:user:password:db:bin:"
>>> > #geo is the name of the column
>>> > DATA "geo from Parcels feature"
>>> > STATUS ON
>>> > TYPE POLYGON
>>> > CLASS
>>> > OUTLINECOLOR 255 0 0
>>> > TEMPLATE "template.html"
>>> > END
>>> > MAXSCALE 40000
>>> > TOLERANCE 0
>>> > TOLERANCEUNITS PIXELS
>>> > END
>>> > I get the following error:
>>> > Warning: [MapServer Error]: SELECT feature.id, feature.vertices,
>>> > geometry.WKB_GEOMETRY from bad mysql query : bad mysql query in
>>> > <filepath
>>> > and name> on line 217
>>> > Can anyone help with this?
>>> > BTW, I tried to use shp2mysql.pl, but got several failures.
>>> > Thanks,
>>> > Don
>> Don Deskins
