MySQL and mapfile
Don Deskins
dldeskins at GMAIL.COM
Tue Apr 5 15:21:34 EDT 2005
Jeff,
The article that I saw is on the mailing list.
All you have to do is to use the command line tool shptree in the form:
shptree shapefile.shp
It creates the .qix files.
On Apr 5, 2005 2:43 PM, Jeff Portwine <jdport at veritime.com> wrote:
> You don't happen to have a link to that post about .qix files do you? I
> have no idea what they are about, but I know that most of my shapefiles
> don't have them. If I can create them and speed up my application I'd love
> to do so :)
> -Jeff
> ----- Original Message -----
> From: "Don Deskins" <dldeskins at GMAIL.COM>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Tuesday, April 05, 2005 2:23 PM
> Subject: Re: [UMN_MAPSERVER-USERS] MySQL and mapfile
> > Steve,
> > Thank you very much for your reply. I am sorry to say that I didn't
> > know there was a ".qix" file. With my database background, I assumed
> > that an indexed database field would be faster than a flat file. Of
> > course, that is correct if the flat file is not index. I searched
> > through the archives and found out what a .qix file was all about. I
> > created one for each of my shapes and sped up download time by 50%.
> > Now on to tiling the shp files :)
> > Thanks again
> > On Apr 5, 2005 12:11 PM, Stephen Woodbridge <woodbri at swoodbridge.com>
> > wrote:
> >> Don Deskins wrote:
> >> > Hello,
> >> > Again, I am new to mapserver. I have finally gotten my map to display
> >> > properly but it is very slow, so I am interested in getting all of the
> >> > data
> >> > into a database (MySQL).
> >> Shapefiles are very fast if they are set up correctly and indexed. You
> >> would be wise to understand and resolve the performance issues before
> >> moving the data to mysql as it is not likely to be faster.
> >> For example do all you shapefiles have *.qix file?
> >> How is your mapfile structured? Are you trying to draw too much detail
> >> at larger zoom values?
> >> When is it slow? Zoomed in or zoomed out or both. If we had some more
> >> information we might be able to help you resolve the performance issues.
> >> Understanding these issues might also help you when you get the data
> >> loaded into mygis.
> >> -Steve W.
> >> > I have data (in .shp, .dbf, and .shx files) that I have converted using
> >> > mygisimport. This produce an sql file which I imported into the MySql
> >> > db.
> >> > I am now having trouble accessing this data with the mapfile. Here is
> >> > what
> >> > I have:
> >> > LAYER
> >> > NAME "SCAP_Cert2004_ParcelsUTM16M"
> >> > CONNECTIONTYPE mygis
> >> > CONNECTION "host:user:password:db:bin:"
> >> > #geo is the name of the column
> >> > DATA "geo from Parcels feature"
> >> > STATUS ON
> >> > TYPE POLYGON
> >> > CLASS
> >> > OUTLINECOLOR 255 0 0
> >> > TEMPLATE "template.html"
> >> > END
> >> > MAXSCALE 40000
> >> > TOLERANCE 0
> >> > TOLERANCEUNITS PIXELS
> >> > END
> >> > I get the following error:
> >> > Warning: [MapServer Error]: SELECT feature.id, feature.vertices,
> >> > geometry.WKB_GEOMETRY from bad mysql query : bad mysql query in
> >> > <filepath
> >> > and name> on line 217
> >> > Can anyone help with this?
> >> > BTW, I tried to use shp2mysql.pl, but got several failures.
> >> > Thanks,
> >> > Don
> > Don Deskins
Don Deskins
