tutorial problem
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Wed Apr 6 10:23:34 EDT 2005
Ferencik,
Hmm, for myself to get this tutorial to work just now with MS4W I made
the following change to example1-9.map:
WEB
TEMPLATE 'example1-9.html'
IMAGEPATH '/ms4w/tmp/ms_tmp/'
IMAGEURL '/ms_tmp/'
END
What happens when you try that?
jeff
Ferencik Ioan wrote:
> I am running MS4W, it is working fine, I downloaded Mapserver tutorial and
> passed through it till example1-9. I have the folowing problem:
> when I type: http://localhost/cgi-bin/mapserv.exe?
> map=c:\ms4w\tutorial\example1-9.map&mode=browse
> I see only 1 map though I should see pursunat to template file 2 maps: one png
> image is generate in map mode and the other in browse mode. Instead of second
> map I see a blank square and inside it is wtritten: Submit query.
> Can you guys help me?
> WEB
> IMAGEPATH 'tmp'
> IMAGEURL 'tmp'
> END
> I believe that i am missing something with WEB object(IMAGEURL)
> Can you give me from what I have written a hint about what should I write at
> IMAGEPATH and IMAGEURL?
> Thanks
> _____________________________________________
> Castiga peste 1000 de premii cu Wella Design!
> http://wella.boom.ro
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
