Identify WMS Layers with ArcGIS
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Apr 6 15:23:21 EDT 2005
Hi Eduin,
I don't know the current status of WMS in ArcGIS. But it used to be that
only ArcXML is supported for a GetFeatureInfo response (identify), but
Mapserver uses a Mapserver flavour of GML 2. So those two don't match.
I expect things to get better when both Mapserver and ArcGIS will
implement GML 3 level 0 profile, and the WMS spec will adopt that as the
"standard" for GetFeatureInfo (or at least most WMS services will support
this).
So probably for now you won't get this to work in the *land of
interoperability*.
Best regards,
Bart
On Wed, 6 Apr 2005 14:24:07 -0500, Eduin Carrillo <yecarrillo at YAHOO.COM>
wrote:
> I'm trying to "identify" WMS layers in ArcGIS with no resutls. Window
> reports
> "Nothing found"
> I'm sure my .map is fine:
> WEB
> MINSCALE 0
> TEMPLATE "template.html"
> METADATA
> wms_extent "940000.00000000 1120000.00000000
> 1211820.35394300 1400000.00000000"
> wms_abstract "Mapa de prueba del servidor WMS"
> wms_encoding "ISO-8859-1"
> wms_opaque "1"
> wms_accesscontraints "none"
> wms_addresstype "mailing address"
> wms_address "Carrera 10 No. 13 - 78"
> wms_city "San Gil"
> wms_stateorprovince "Santander"
> wms_postcode ""
> wms_country "COLOMBIA"
> wms_contactelectronicmailaddress "yecarrillo at cas.gov.co"
> wms_contactfacsimiletelephone "+57+7 7238110"
> wms_contactperson "Eduin Yesid Carrillo Vega"
> wms_contactorganization "Corporación Autónoma Regional de
> Santander CAS"
> wms_contactposition "Coordinador SIG"
> wms_contactvoicetelephone "+57+7 7236888"
> wms_feature_info_mime_type "text/plain"
> wms_fees "none"
> wms_keywordlist "Prueba"
> wms_title "Prueba"
> wms_timeformat "YYYY-MM-DDTHH, YYYY-MM-DDTHH:MM,
> YYYY-MM-DD HH:MM:SS"
> wms_onlineresource
> "http://sig.cas.gov.co/mapas/prueba?"
> wms_srs "EPSG:21892"
> END
> END #WEB
> GetCapabilities:
> <GetFeatureInfo>
> <Format>text/plain</Format>
> <Format>application/vnd.ogc.gml</Format>
> <DCPType>
> <HTTP>
> <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
> xlink:href="http://sig.cas.gov.co/mapas/prueba?"/></Get>
> <Post><OnlineResource
> xlink:href="http://sig.cas.gov.co/mapas/prueba?"/></Post>
> </HTTP>
> </DCPType>
> </GetFeatureInfo>
> What is wrong?
> Thanks
> yecarrillo at yahoo.com
> COLOMBIA
> _________________________________________________________
> Do You Yahoo!?
> Información de Estados Unidos y América Latina, en Yahoo! Noticias.
> Visítanos en http://noticias.espanol.yahoo.com
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
