Unexpected WFS GetFeature results
    Yewondwossen Assefa
    assefa at DMSOLUTIONS.CA
    Thu Apr  7 14:55:47 PDT 2005
Tom,
  I have corrected the problem in the latest CVS. There is a bug
attached to it (Bug 1308). Pleas let me know how it goes.
Later,
Kralidis,Tom [Burlington] wrote:
> Assefa,
> I tested this scenario with CVS 20050328 (the day before you committed
> to mapogcfilter.c and mapogcfilter.h), and everything works fine.
> So the problem is somewhere in those changes.
> Here's the actual OGC filter:
> <Filter>
>  <And>
>   <BBOX>
>    <PropertyName>NAME</PropertyName>
>     <Box srsName="EPSG:4326">
>      <coordinates>-141.84,21.599999999999994 -56.16,74.16</coordinates>
>     </Box>
>   </BBOX>
>   <Or>
>    <Or>
>     <PropertyIsLike wildCard="*" singleChar="." escape="!">
>      <PropertyName>title</PropertyName>
>      <Literal>benthic</Literal>
>     </PropertyIsLike>
>      <PropertyName>abstract</PropertyName>
>     </PropertyIsLike>
>    </Or>
>     <PropertyName>keywords</PropertyName>
>    </PropertyIsLike>
>   </Or>
>  </And>
> </Filter>
> ..Tom
>>-----Original Message-----
>>From: UMN MapServer Users List
>>[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of
>>Yewondwossen Assefa
>>Sent: Wednesday, 06 April, 2005 13:03
>>To: MAPSERVER-USERS at LISTS.UMN.EDU
>>Subject: Re: [UMN_MAPSERVER-USERS] Unexpected WFS GetFeature results
>>Tom,
>>  I did make some changes recently to the way filters were
>>handled for postgis layers (Bug
>>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1292).
>>  It's probably related to thoses changes. Is it easy for you
>>to test it against 4.4.x releases ? If you can test and It
>>works I will start looking into the code to see what the problem is.
>>Later,
>>>Hi,
>>>(MapServer CVS, FC2, latest stable supporting libs).
>>>I have a WFS instance running against a PostGIS table, and when I
>>>invoke a Filter'd GetFeature operation (bbox AND a nested OR), I
>>>expect one result to be returned (only one record in the DB
>>satisfies
>>>this request).
>>>I've attached a sample HTML form page to correctly invoke
>>the request.
>>>However, I receive all records back in the DB.
>>>Any idea what's going on here?  FYI, here's my DATA string in the
>>>LAYER
>>>object:
>>>  DATA "the_geom from (select service_endpoints.organization as
>>>organization,service_endpoints.endpoint_getresource as
>>>endpoint_getresource,service_endpoints.service_type as
>>>service_type,service_endpoints.service_version as
>>>service_version,service_resources.the_geom as
>>>the_geom,service_resources.resource_id as
>>>resource_id,service_resources.service_id as
>>>service_id,service_resources.name as
>>name,service_resources.title as
>>>title,service_resources.abstract as
>>>abstract,service_resources.keywords
>>>as keywords,service_resources.dataurl as
>>>dataurl,service_resources.metadataurl as
>>>metadataurl,service_resources.legendurl as
>>>legendurl,service_resources.scale_min as
>>>scale_min,service_resources.scale_max
>>> as scale_max,service_resources.srs as
>>srs,service_endpoints.format_list
>>>as format_list,service_resources.style_list as
>>>style_list,service_resources.time_extent as
>>>time_extent,service_resources.queryable as queryable from
>>>service_resources inner join service_endpoints on
>>>service_endpoints.service_id =
>>service_resources.service_id) as t using
>>>unique resource_id"
>>>Thanks
>>>..Tom
>>Assefa Yewondwossen
>>Software Analyst
>>Email: assefa at dmsolutions.ca
>>http://www.dmsolutions.ca/
>>Phone: (613) 565-5056 (ext 14)
>>Fax:   (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax:   (613) 565-0925
More information about the MapServer-users
