Unexpected WFS GetFeature results
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Apr 7 20:04:05 EDT 2005
Assefa,
I retested, no luck. Now I get no results returned running the same
test.
..Tom
> -----Original Message-----
> From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> Sent: Thursday, 07 April, 2005 17:56
> To: Kralidis,Tom [Burlington]
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Unexpected WFS GetFeature results
> Tom,
> I have corrected the problem in the latest CVS. There is a bug
> attached to it (Bug 1308). Pleas let me know how it goes.
> Later,
> Kralidis,Tom [Burlington] wrote:
> > Assefa,
> > I tested this scenario with CVS 20050328 (the day before
> you committed
> > to mapogcfilter.c and mapogcfilter.h), and everything works fine.
> > So the problem is somewhere in those changes.
> > Here's the actual OGC filter:
> > <Filter>
> > <And>
> > <BBOX>
> > <PropertyName>NAME</PropertyName>
> > <Box srsName="EPSG:4326">
> > <coordinates>-141.84,21.599999999999994
> -56.16,74.16</coordinates>
> > </Box>
> > </BBOX>
> > <Or>
> > <Or>
> > <PropertyIsLike wildCard="*" singleChar="." escape="!">
> > <PropertyName>title</PropertyName>
> > <Literal>benthic</Literal>
> > </PropertyIsLike>
> > <PropertyName>abstract</PropertyName>
> > </PropertyIsLike>
> > </Or>
> > <PropertyName>keywords</PropertyName>
> > </PropertyIsLike>
> > </Or>
> > </And>
> > </Filter>
> > ..Tom
> >>From: UMN MapServer Users List
> >>[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of
> >>Yewondwossen Assefa
> >>Sent: Wednesday, 06 April, 2005 13:03
> >>To: MAPSERVER-USERS at LISTS.UMN.EDU
> >>Tom,
> >> I did make some changes recently to the way filters were
> >>handled for postgis layers (Bug
> >>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1292).
> >> It's probably related to thoses changes. Is it easy for you
> >>to test it against 4.4.x releases ? If you can test and It
> >>works I will start looking into the code to see what the problem is.
> >>Later,
> >>>Hi,
> >>>(MapServer CVS, FC2, latest stable supporting libs).
> >>>I have a WFS instance running against a PostGIS table, and when I
> >>>invoke a Filter'd GetFeature operation (bbox AND a nested OR), I
> >>>expect one result to be returned (only one record in the DB
> >>satisfies
> >>>this request).
> >>>I've attached a sample HTML form page to correctly invoke
> >>the request.
> >>>However, I receive all records back in the DB.
> >>>Any idea what's going on here? FYI, here's my DATA string in the
> >>>LAYER
> >>>object:
> >>> DATA "the_geom from (select service_endpoints.organization as
> >>>organization,service_endpoints.endpoint_getresource as
> >>>endpoint_getresource,service_endpoints.service_type as
> >>>service_type,service_endpoints.service_version as
> >>>service_version,service_resources.the_geom as
> >>>the_geom,service_resources.resource_id as
> >>>resource_id,service_resources.service_id as
> >>>service_id,service_resources.name as
> >>name,service_resources.title as
> >>>title,service_resources.abstract as
> >>>abstract,service_resources.keywords
> >>>as keywords,service_resources.dataurl as
> >>>dataurl,service_resources.metadataurl as
> >>>metadataurl,service_resources.legendurl as
> >>>legendurl,service_resources.scale_min as
> >>>scale_min,service_resources.scale_max
> >>> as scale_max,service_resources.srs as
> >>srs,service_endpoints.format_list
> >>>as format_list,service_resources.style_list as
> >>>style_list,service_resources.time_extent as
> >>>time_extent,service_resources.queryable as queryable from
> >>>service_resources inner join service_endpoints on
> >>>service_endpoints.service_id =
> >>service_resources.service_id) as t using
> >>>unique resource_id"
> >>>Thanks
> >>>..Tom
> >>Assefa Yewondwossen
> >>Software Analyst
> >>Email: assefa at dmsolutions.ca
> >>http://www.dmsolutions.ca/
> >>Phone: (613) 565-5056 (ext 14)
> >>Fax: (613) 565-0925
> Assefa Yewondwossen
> Software Analyst
> Fax: (613) 565-0925
