Install/Config Problems
    Christian Schroeder
    mailings at ABIWOOD99.DE
    Fri Apr  8 04:11:30 PDT 2005
Hello Jeffrey,
I don't know what the problem concerning the php-module is, but once I had a
problem with the mapserv CGI-Module, too and got the error message 'Premature
end of script headers'.
You can try to run the mapserv CGI-Module from console to get a more detailed
error message.
To do so, you have to call
./mapserv QUERY_STRING=map=/home/www/map1.map&mode=map
This helped me to get more informations about which module failed.
Regards,
Christian
Jeffrey Johnson <ortelius at GMAIL.COM>:
> Hello,
> I am attempting to install and configure
> mapserver+phpmapscript+chameleon on my debian/linux box and have run
> into a currently insurmountable issue. apache+php config is fine.
> Haven't really tested php extensively, but some simple tests work ok.
> I have configured Mapserver with the following command.
> ./configure --with-proj --with-ogr --with-gdal --with-jpeg --with-png
> --with-tiff --with-postgis --with-wfs --with-wcs --with-wms
> --with-wfsclient --with-wmsclient --with-php=/usr/src/php-4.3.10/
> then ran make and copied the 'mapserv' executable into the cgi-bin
> directory. When attempting to access a mapfile using the cgi-script
> directly
> http://domainname.com/cgi-bin/mapserv?map=/home/www/map1.map&mode=map
>  I am returned '500 Internal Server error'. The logfile contains
> 'Premature end of script headers: /usr/local/apache/cgi-bin/mapserv'
> If I re-run configure and remove the --with-php=/usr/src/php-4.3.10/
> directive and recompile, the map displays fine.
> I had originally compiled PHP as a DSO, but couldnt get mapserver to
> work this way either, so reverted to compiling php into apache
> directly.
> Any ideas?
> Thanks in advance,
> Jeff
More information about the MapServer-users
