coordinate conversion problem
Didrik Pinte
dpinte at ITAE.BE
Fri Apr 8 09:52:55 EDT 2005
I'm using a lot of rasters and one shape file in Esri
NTF_France_Lambert_II coordinates
I've translated NTF_France_Lambert_II in epsg:27572
I will have a layer of GPS points in latlong coordinates. To simulate
this, I took a shapefile in Esri NTF_France_Lambert_II coordinates and
convert it using ArcGIS to GCS_WGS_84.
I've translated GCS_WGS_84 to epsg:4326
When I look at the map, my latlong points are nearly 400 km on the left
of the original points ...
How can I solve the problem ? Did I choosed a bad epsg reference ?
Thank you in advance for your help
Didrik
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050408/91a9e55c/attachment.bin
