coordinate conversion problem
Didrik Pinte
dpinte at ITAE.BE
Sat Apr 9 11:23:29 EDT 2005
Le samedi 09 avril 2005 à 11:09 -0400, Frank Warmerdam a écrit :
> Didrik,
> There are problems with the translations in PROJ.4 for coordinate systems
> with alternate prime meridians, and coordinate systems based on gradians.
> One related bug is:
> http://bugzilla.remotesensing.org/show_bug.cgi?id=811
> I think there are others in the PROJ.4 bugzilla more specific to your problem.
> The gist of it is, you will need to correct the definition manually in your
> PROJ.4 "epsg" file. This is in /usr/local/share/proj/epsg on unix/linux.
> Best regards,
Thank you very much for the information. That is very annoying ... I
need to make that work for monday. Some stress for the week-end.
Is there a good way of doing this by hand ? Just by "try and error"
overlaying the two layers ?
Didrik
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050409/91a89f98/attachment.bin
