coordinate conversion problem
Frank Warmerdam
fwarmerdam at GMAIL.COM
Sat Apr 9 12:37:29 EDT 2005
On Apr 9, 2005 11:23 AM, Didrik Pinte <dpinte at itae.be> wrote:
> Thank you very much for the information. That is very annoying ... I
> need to make that work for monday. Some stress for the week-end.
> Is there a good way of doing this by hand ? Just by "try and error"
> overlaying the two layers ?
Didnik,
I would suggest:
o review bug reports, and discussion of this topic (search for NTF
would likely be helpful) on the PROJ.4, gdal-dev, mapserver and
perhaps postgis mailing lists.
o The problem is likely just the +lon_0 setting which likely needs
to be adjusted +- the longitude between greenwich and paris. This
is 2d20'14.025"
You may email me directly and I will try to be helpful if you can't
figure it out yourself or from available sources.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
