Install/Config Problems
Giridhar Manepalli
gmanepal at GMAIL.COM
Sat Apr 9 18:21:35 EDT 2005
Hello Jeff,
I am facing with the same problem now. I installed mapserver on one
machine and it worked fine. Currently, I am trying to install on
Fedora Core 3, with php-4.3.11. I built it as a DSO similar to the
working model.
I also tried debugging using gdb, but it looks it has fallen into
infinite loop. I am unable to comprehend the reason for this
segmentation fault. Although, from my earlier working model, it is
only evident that I should try my earlier combinations.
If you get the break through, let the list know about it. I will do
the same as well.
Good Luck,
Giridhar Manepalli
On Apr 8, 2005 10:14 AM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> Only a generic segmentation fault is returned. Perhaps I could go back
> to using PHP as a DSO. Is there some documentation online about how to
> get mapscript configured when PHP is configured this way. I have found
> some discussion of this on the list archives, but nothing that really
> seemed to help.
> Thanks,
> Jeff
> On Apr 8, 2005 4:11 AM, Christian Schroeder <mailings at abiwood99.de> wrote:
> > Hello Jeffrey,
> > I don't know what the problem concerning the php-module is, but once I had a
> > problem with the mapserv CGI-Module, too and got the error message 'Premature
> > end of script headers'.
> > You can try to run the mapserv CGI-Module from console to get a more detailed
> > error message.
> > To do so, you have to call
> > ./mapserv QUERY_STRING=map=/home/www/map1.map&mode=map
> > This helped me to get more informations about which module failed.
> > Regards,
> > Christian
> > Jeffrey Johnson <ortelius at GMAIL.COM>:
> > > Hello,
> > > I am attempting to install and configure
> > > mapserver+phpmapscript+chameleon on my debian/linux box and have run
> > > into a currently insurmountable issue. apache+php config is fine.
> > > Haven't really tested php extensively, but some simple tests work ok.
> > > I have configured Mapserver with the following command.
> > > ./configure --with-proj --with-ogr --with-gdal --with-jpeg --with-png
> > > --with-tiff --with-postgis --with-wfs --with-wcs --with-wms
> > > --with-wfsclient --with-wmsclient --with-php=/usr/src/php-4.3.10/
> > > then ran make and copied the 'mapserv' executable into the cgi-bin
> > > directory. When attempting to access a mapfile using the cgi-script
> > > directly
> > > http://domainname.com/cgi-bin/mapserv?map=/home/www/map1.map&mode=map
> > > I am returned '500 Internal Server error'. The logfile contains
> > > 'Premature end of script headers: /usr/local/apache/cgi-bin/mapserv'
> > > If I re-run configure and remove the --with-php=/usr/src/php-4.3.10/
> > > directive and recompile, the map displays fine.
> > > I had originally compiled PHP as a DSO, but couldnt get mapserver to
> > > work this way either, so reverted to compiling php into apache
> > > directly.
> > > Any ideas?
> > > Thanks in advance,
> > > Jeff
