I can't see my maps
Shashi Gireddy
gireddy at GMAIL.COM
Mon Apr 11 11:41:38 EDT 2005
if your are working on windows, may be the image path is not
accessible due to security reasons, go to that directory properties
and select security and set appropriate settings(I had IIS, this may
not be the reason, just give a try). check if the image is created by
going to the image folder (delete all images once) and rerun the
program and the check if the image is generated. for me when I used
dynamic postgis (i.e generating the map from php code) a blank map was
generated (I am trying for a month,I still didn't get the sol for t
his).
On Apr 10, 2005 3:19 PM, CJ <chloejackson at totalise.co.uk> wrote:
> Can anyone help me? I have Apache, PHP, MySQL setup on my local server and
> have been trying to add in MapServer. I have installed and configured all
> the elements and have been working with the Itasca demo workshop.
> So far I can get the webpage working but there is no map in the map frame.
> The map is there and the Index.html points to its directory, so why can't it
> find the map?
> I'd appreciate any help with this. I'm a total newbie to MapServer, etc.
Shashi Kiran Reddy. Gireddy,
Graduate Assistant,
CBER, University of Alabama.
http://www.cs.ua.edu/shashi
Home: 205-752-5137 Cell: 205-657-1438
