I can't see my maps
Ed McNierney
ed at TOPOZONE.COM
Mon Apr 11 19:23:13 EDT 2005
Chloe -
Please always reply to the entire list, not just to one person. The
first person to answer might not have all the answers, and they might
not have time to take on all your follow-up questions personally <g>.
As I said earlier, look at the generated HTML you're viewing. What is
the URL in the <img> tag where the map is supposed to be? Does it look
like you expect? If not, change the IMAGEURL to fix it.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: ChloeJackson [mailto:chloejackson at totalise.co.uk]
Sent: Monday, April 11, 2005 6:18 PM
To: Ed McNierney
Subject: Re: [UMN_MAPSERVER-USERS] I can't see my maps
Hi Ed,
I get a grey screen which changes to a paler grey if I click in the map
window. However, if I click in the map window, i get a message that 'c
is not a registered protocol'. There is also a message saying 'This is
the Map'. I seem to be happily creating .png files in each time I
refresh the page, but still can't see the map.
Can I just check with you what the IMAGEURL should point to? I have
currently have it pointing to the workshop directory.
CJ
Ed McNierney wrote:
>CJ -
>>From your description, you are likely getting a "broken link" to the
>image, rather than a blank image. Is that correct? It's an important
>distinction.
>Look at the generated HTML source and check the URL of the map image.
>The IMAGEURL string in your map file is used to generate this URL. If
>the URL in the HTML output does not point to your generated map image,
>modify the IMAGEURL (or configure your Web server's settings) so the
>URL points to the image.
> - Ed
>Ed McNierney
>ed at topozone.com
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
>On Behalf Of CJ
>Sent: Sunday, April 10, 2005 4:19 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] I can't see my maps
>Can anyone help me? I have Apache, PHP, MySQL setup on my local server
>and have been trying to add in MapServer. I have installed and
>configured all the elements and have been working with the Itasca demo
>workshop.
>So far I can get the webpage working but there is no map in the map
>frame.
>The map is there and the Index.html points to its directory, so why
>can't it find the map?
>I'd appreciate any help with this. I'm a total newbie to MapServer,
>etc.
