problem with gd
Camden Daily
cdaily at GMAIL.COM
Mon Apr 11 15:15:15 EDT 2005
GD is a graphics library. I'm fairly certain that mapserver uses it
to actually draw the maps, so it's pretty important.
Did you install gd as a package or from source? If as a package, did
you install gd-devel as well? If you give some details for your setup
as well as the ./configure command you're using on mapserver, we might
be able to help a bit.
-Camden Daily
