Difference shp2img <-> mapserv.exe
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Apr 11 16:30:16 EDT 2005
Wouter,
You can also try layers=all on your URL, if you have a fairly resent
version it has the same effect as forcing all your layers on. It's
behavior is similar to shp2img
-Steve W.
Frank Warmerdam wrote:
> On Apr 11, 2005 3:45 PM, Wouter Schaubroeck
> <wouter.schaubroeck at gmail.com> wrote:
>>Hi all,
>>I have this problem: with shp2img, my mapfile, and the corresponding
>>image shows up, but with mapserv.exe it doesn't. Actually, it does, but
>>it is blank.
>>I've checked both with dependency walker, but there were no problems. Is
>>there a solution for my problem, or is this very machine related?
>>Btw: i'm running Apache 2.0.48 on windows xp.
>>And this is how i call my mapserver
>>/cgi-bin/mapserv.exe?map=C:/Program Files/Apache
>>Group/Apache2/htdocs/herten/herten.map&mode=map
> Wouter,
> You didn't mention what commandline you use with shp2img.
> I see your layer STATUS is set to ON. This really just means
> "potentially available", and it has to be turned on by an appropriate
> (hidden) form variable in the mapserv.exe context I believe. Try
> setting the STATUS to DEFAULT. If that works, then you need to
> read up on how layers are enabled and disabled in mapserver.
> If that doesn't help then the issue is something else...
> Good luck,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
