PHP MapScript zoompoint
Giridhar Manepalli
gmanepal at GMAIL.COM
Mon Apr 11 19:05:36 EDT 2005
This helped me a lot. Thanks!
On Apr 6, 2005 3:01 AM, Matthew Whiting <whiting at maxnet.co.nz> wrote:
> After hours working on this, I finally found the problem.
> Setting x and y for the PointObj like this:
> $point->x = $x;
> $point->y = $y;
> does not work.
> This does:
> $point->setxy($x,$y);
> Why is this a problem?
> Interestingly after setting the points explicitly (as opposed to setxy())
> and then printing the contents, it seems the values are actually set!
> Matthew
> Hello all,
> Have been trying without success to successfully implement a zoom out
> feature in my application using the zoompoint() function and -2 as the zoom
> factor. For some reason, the image does not end up centred on the point
> clicked on but on a different spot altogether. I'm getting nowhere with
> this. I tried manually changing the extent and this works fine. Any
> suggestions?
> Thanks
> Matthew
