Missing files or directories
Nuri nuri at NUSVIRTUAL.COM
Tue Apr 12 02:55:15 PDT 2005
I'm begin to use Mapserver.
It is running under Windows XP with IIS. I completed install Mapserver and
it runs.
I have several examples of how to use it, but they haven't got all sources
to execute in my PC.
I'm trying to run in my PC the example that appears in:
http://terrasip.gis.umn.edu/projects/tutorial/example1-1.html
I have the shapes and databases used in it, but when I run the map writing
in browser URL:
http://nuri/cgi-bin/mapserv.exe?
map=d:/webserver/mapserver2/mapa01.map&mode=map
it appears the following error:
msProcessProjection(): Projection library error. No such file or directory
Someone could explain me which file or directory is it looking for?
The map file I'm using is a simple one:
MAP
  IMAGETYPE PNG
  EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
  SIZE 400 300
  SHAPEPATH "data"
  IMAGECOLOR 255 255 255
  PROJECTION
    "proj=laea"
    "ellps=clrk66"
    "lat_0=45"
    "lon_0=-100"
  # Alternatively, you can specify an EPSG code.
  # "init=epsg:2163"
  END
  # Start of LAYER DEFINITIONS --------------------------------------------
  LAYER # States polygon layer begins here
    NAME states
    DATA states_ugl
    STATUS DEFAULT
    TYPE POLYGON
    PROJECTION
      "init=epsg:4269"
    END
    CLASS
      COLOR 232 232 232
      OUTLINECOLOR 32 32 32
    END
  END # States polygon layer ends here
  # End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
Thank you
More information about the MapServer-users mailing list
