Missing files or directories
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Tue Apr 12 06:08:50 EDT 2005
this indicates Mapserver needs PROJ and it tries to locatie it default at c:\proj
If you want another directory you can specify an environment called variable PROJ_LIB with the respective path as value.
Download PROJ files from:
http://dl2.maptools.org/dl/proj/proj446_win32_bin.zip
and for the EPSG codes (put the epsg file in c:\proj\):
http://dl2.maptools.org/dl/proj4-epsg-with-42xxx-and-esri.zip
Best regards,
Bart
Syncera-ITSolutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Nuri <nuri at NUSVIRTUAL.COM> 04/12/05 11:55am >>>
I'm begin to use Mapserver.
It is running under Windows XP with IIS. I completed install Mapserver and
it runs.
I have several examples of how to use it, but they haven't got all sources
to execute in my PC.
I'm trying to run in my PC the example that appears in:
http://terrasip.gis.umn.edu/projects/tutorial/example1-1.html
I have the shapes and databases used in it, but when I run the map writing
in browser URL:
http://nuri/cgi-bin/mapserv.exe?
map=d:/webserver/mapserver2/mapa01.map&mode=map
it appears the following error:
msProcessProjection(): Projection library error. No such file or directory
Someone could explain me which file or directory is it looking for?
The map file I'm using is a simple one:
MAP
IMAGETYPE PNG
EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
SIZE 400 300
SHAPEPATH "data"
IMAGECOLOR 255 255 255
PROJECTION
"proj=laea"
"ellps=clrk66"
"lat_0=45"
"lon_0=-100"
# Alternatively, you can specify an EPSG code.
# "init=epsg:2163"
END
# Start of LAYER DEFINITIONS --------------------------------------------
LAYER # States polygon layer begins here
NAME states
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4269"
END
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
Thank you
