Problem with MODIS images
Marco Marsella
m.marsella at ITWORKS.IT
Tue Apr 12 09:08:23 EDT 2005
Hi list,
I am having problems with some MODIS images. They show as skewed white
squares on black background. I attach a small screen capture GIF.
Mapserver is 4.4.1, gdalinfo --formats reports
Supported Formats:
VRT (rw+): Virtual Raster
GTiff (rw+): GeoTIFF
NITF (rw+): National Imagery Transmission Format
HFA (rw+): Erdas Imagine Images (.img)
SAR_CEOS (ro): CEOS SAR Image
CEOS (ro): CEOS Image
ELAS (rw+): ELAS
AIG (ro): Arc/Info Binary Grid
AAIGrid (rw): Arc/Info ASCII Grid
SDTS (ro): SDTS Raster
OGDI (ro): OGDI Bridge
DTED (rw): DTED Elevation Raster
PNG (rw): Portable Network Graphics
JPEG (rw): JPEG JFIF
MEM (rw+): In Memory Raster
JDEM (ro): Japanese DEM (.mem)
GIF (rw): Graphics Interchange Format (.gif)
ESAT (ro): Envisat Image Format
BSB (ro): Maptech BSB Nautical Charts
XPM (rw): X11 PixMap Format
BMP (rw+): MS Windows Device Independent Bitmap
AirSAR (ro): AirSAR Polarimetric Image
RS2 (ro): RadarSat 2 XML Product
PCIDSK (rw+): PCIDSK Database File
ILWIS (rw+): ILWIS Raster Map
GMT (rw): GMT NetCDF Grid Format
netCDF (ro): network Common Data Format
HDF4 (ro): Hierarchical Data Format Release 4
HDF4Image (rw+): HDF4 Dataset
PNM (rw+): Portable Pixmap Format (netpbm)
DOQ1 (ro): USGS DOQ (Old Style)
DOQ2 (ro): USGS DOQ (New Style)
ENVI (rw+): ENVI .hdr Labelled
EHdr (rw+): ESRI .hdr Labelled
PAux (rw+): PCI .aux Labelled
MFF (rw+): Atlantis MFF Raster
MFF2 (rw+): Atlantis MFF2 (HKV) Raster
FujiBAS (ro): Fuji BAS Scanner Image
GSC (ro): GSC Geogrid
FAST (ro): EOSAT FAST Format
BT (rw+): VTP .bt (Binary Terrain) 1.3 Format
LAN (ro): Erdas .LAN/.GIS
CPG (ro): Convair PolGASP
IDA (rw+): Image Data and Analysis
NDF (ro): NLAPS Data Format
JPEG2000 (rw): JPEG-2000 part 1 (ISO/IEC 15444-1)
L1B (ro): NOAA Polar Orbiter Level 1b Data Set
FIT (rw): FIT Image
MrSID (ro): Multi-resolution Seamless Image Database (MrSID)
USGSDEM (rw): USGS Optional ASCII DEM (and CDED)
GXF (ro): GeoSoft Grid Exchange Format
and gdalinfo on the image file reports
Driver: GTiff/GeoTIFF
Size is 12205, 10098
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (100.529340,-1.327067)
Pixel Size = (0.00208000,-0.00208000)
Metadata:
TIFFTAG_SOFTWARE=MRTSwath
Corner Coordinates:
Upper Left ( 100.5293404, -1.3270670)
Lower Left ( 100.5293404, -22.3309070)
Upper Right ( 125.9157405, -1.3270670)
Lower Right ( 125.9157405, -22.3309070)
Center ( 113.2225405, -11.8289870)
Band 1 Block=12205x1 Type=UInt16, ColorInterp=Gray
Any suggestion, please ?
TIA
Marco
Type: image/tiff
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050412/3a196032/pastedGraphic2.tiff
