Perl API method setProjection doesn't work.
SUBSCRIBE MAPSERVER-USERS Cave
caveeagle at POCHTAMT.RU
Wed Apr 13 03:46:21 PDT 2005
> Ah. Hang on.
> The second is wrong. The two others seems to do the same thing.
Unfortunately, it’s right. All methods of solving my problem do not work.
> Anyway - I think the problem is that setProjection() doesn't change
> your extents, so you've probably zoomed in very closely on a spot in
> the Pacific Ocean.
To test this hypothesis, I have calculate the extents with proj utility,
and set them manually. Unfortunately, it didn’t the help also.
It is significant that setting the projection in query string from CGI-
script works successfully.
More information about the MapServer-users
