Mapserver & Oracle: WMS request works, but plain mode=map request doesn't
Jussi Rasinmäki jussi.rasinmaki at HELSINKI.FI
Thu Apr 14 11:03:18 PDT 2005
Indeed..., problem solved.
Thanks,
Jussi
----- Original Message -----
From: "Bart van den Eijnden" <bartvde at xs4all.nl>
To: "Jussi Rasinmäki" <jussi.rasinmaki at helsinki.fi>;
<MAPSERVER-USERS at lists.umn.edu>
Sent: Wednesday, April 13, 2005 8:49 PM
Subject: Re: [UMN_MAPSERVER-USERS] Mapserver & Oracle: WMS request works,
> Hi,
> Can you try defining STATUS DEFAULT at your LAYER?
> Best regards,
> Bart
> On Thu, 14 Apr 2005 20:38:14 +0300, Jussi Rasinmäki
> <jussi.rasinmaki at HELSINKI.FI> wrote:
>> Hi all,
>> I've got a map file that uses Oracle as data source (see below)
>> The following request produces a blank page:
>> http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/testi/testi2.map&mode=map
>> but this one
>> http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/testi/testi2.map&request=map&layers=maa&bbox=2499999,6849999,2530000,6870000&version=1.1.0&format=png&width=500&height=500
>> returns what it is supposed to.
>> Why?
>> Cheers,
>> Jussi Rasinmäki
>> MAP
>>   IMAGETYPE PNG
>>   EXTENT 2499999 6849999 2530000 6870000
>>   SIZE 400 300
>>   IMAGECOLOR 255 255 255
>>   PROJECTION
>>    "init=epsg:2392"
>>   END
>>   # Start of LAYER
>> EFINITIONS  ---------------------------------------------
>>   LAYER
>>     NAME maa
>>     TYPE POLYGON
>>     CONNECTIONTYPE ORACLESPATIAL
>>     CONNECTION "usr/psw at sid"
>>     DATA "GEOLOC FROM MAA USING SRID 294913"
>>     DUMP TRUE
>>     CLASS
>>      OUTLINECOLOR 0 0 0
>>      COLOR 0 128 128
>>     END
>>     PROJECTION
>>       "init=epsg:2392"
>>     END
>>   END # Maa polygon layer ends here
>>   # End of LAYER DEFINITIONS -------------------------------
>> END # end of map file/object
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
More information about the MapServer-users mailing list
